How "analog" do you want your output? What is the end result you want to achieve?
You can use pwm to switch pretty quickly to 'simulate' analog, but then again, if you are trying to send a signal to .50 cent analog component that could be replaced with a .50 cent digital one, it may not be worth the trouble.
