Hello! I'm hoping someone could take a look at my code here for a project I'm working on. I'm confident in my hardware setup, pictured below, but the code needs review.
Here's my circuit. PIC18F4550 connected to a VS1011 and an SD card via SPI. Pretty simple, hardware wire.
I'm using CCS C compiler. My program needs to play an MP3 file, and flash a set of LEDS whenever a switch is closed. I have attached a zip of my code, and I have posted my main file.
This is just the main section. Please refer to my zip file for the rest. I just need to know if all of this will work as intended. Thanks in advance!
Rich (BB code):
#include "M6GDeluxe.h"
#include "mmc_driver.h"
#include "vs1011_driver.h"
#include "fat_driver.h"
unsigned int32 current_sector;
unsigned int32 current_file;
unsigned char play_sound;
unsigned char ammo_count;
unsigned char lzr_on;
unsigned char FIRED;
//General Functions
void player_init()
ADCON1 = 0b00001111; // Port A Digital I/O
TRIS_A = 0b00100000; // PortA.5 Input
TRIS_B = 0b11110001; // PortB Inputs
volume = 0x7F; // Volume = 127
current_sector = 0x00;
current_file = 0;
play_sound = 0;
ammo_count = 8;
lzr_on = 0;
MUZZLE = 0;
FIRED = 0;
void main()
while (TRIGGER)
FIRED = 0;
if (!TRIGGER)
delay_ms(20);
if( !TRIGGER)
if (FIRED == 0)
if (ammo_count > 0)
current_file = 0;
MUZZLE = 1;
play_sound = 1;
ammo_count --;
FIRED = 1;
delay_ms(75);
MUZZLE = 0;
delay_ms(155);
else
current_file = 1;
play_sound = 1;
delay_ms(230);
if (!RELOAD)
ammo_count = 8;
if (!LZRSW)
delay_ms(20);
if (!LZRSW)
if (lzr_on == 0)
LZR = 1;
else
LZR = 0;
int mmc_result;
char cmd;
player_init();
delay_ms(10);
mmc_result = mmc_init();
LED = mmc_result;
if (mmc_result != 0)
while (1);
delay_ms(100);
resetvs1011_hard();
blink_led(3);
find_first_fat32_partition();
read_volumeid();
while (play_sound == 1)
//mmc_read_block_to_vs1011(current_sector);
//current_sector++;
cmd = play_file(current_file);
