I want to connect an external ADC to PIC18f4550, on the stream paralel port. I read in the datasheet that it is possible that USB to transfer data directly in the endpoint. Can you help me choose an external ADC?
The speed should be at least 10Msample /sec, to be compatible with streaming port.
Does anybody succeeded to make this work(establish a high speed transfer in this configuration)?
One idea is to use ADS931 or TLC5540 or AD9280ARSZ.
