pic18f4550 ADC
Discussion in 'Embedded Systems and Microcontrollers' started by Anjanav, Jul 3, 2010.
  1. Anjanav
    Mar 2, 2010
    16
    Hi...
    for acquiring 4 analog inputs of PIC18F4550 am using a condition like(if i give 1 & 2 as input channel 1 and channel 2 value should get displayed)
    where 1 starting channel number and 2 end of channel number
    I tried this using for loop but am not getting any proper values...
    correct me whether am correct...
    awaiting for ur replies...
    thanks,
  2. retched
    Dec 5, 2009
    5,201
    313
    You might want to post your code, as I cant make any sense of what you have said in regard to the conditions you placed.
    Remember to use the [C0DE] and [/C0DE] tags to surround your code when posting it.
    Click on go advanced (Next to the 'Post Quick Reply' button)
    At the top of the editor, you will see a '#' button. Clicking that will add the CODE tags.
  3. Tahmid
    Jul 2, 2008
    344
    27
    Here's what I would do in mikroBASIC. You can get the idea from here and convert to your own code.
    Code ( (Unknown Language)):
    1. sub procedure ScanADCs(dim StartChannel as byte, dim ChannelNum as byte)
    2.        for Temp = 0 to 7
    3.            ADVal[Temp] = 0
    4.        next Temp
    5.
    6.        for Temp = StartChannel to ChannelNum
    7.            ADVal[Temp] = ADC_Read(Temp)
    8.        next Temp
    9.
    10.        Ch0 = ADVal[0]
    11.        Ch1 = ADVal[1]
    12.        Ch2 = ADVal[2]
    13.        Ch3 = ADVal[3]
    14.        Ch4 = ADVal[4]
    15.        Ch5 = ADVal[5]
    16.        Ch6 = ADVal[6]
    17.        Ch7 = ADVal[7]
    18.
    19. end sub
    Call the subroutine like
    1. ScanADCs(0,2)
    Hope this helps.
    Tahmid.
  4. Anjanav
    Mar 2, 2010
    16
    thanks for your replies retched and Tahmid...
    here is my code...
    1. void Get_Start_End(unsigned char a,unsigned char b)
    2. {
    3. int l,m,temp5;
    4. char a_buffer[3],c2[3][3],x;
    5. for(x = a, l=0; x<=a+b-1; x++,l++)
    6.  {
    7.    x = x & 0x07;
    8.    ADCON0bits.CHS0 = (x & 0b00000001);
    9.    ADCON0bits.CHS1 = ((x & 0b00000010)>>1);
    10.    ADCON0bits.CHS2 = ((x & 0b00000100)>>2);
    11.
    12.   ADCON0bits.GO = 1;
    13.   while(ADCON0bits.NOT_DONE);
    14.
    15.   temp5 = ReadADC();
    16.   itoa(temp5/2,a_buffer);
    17.     for(m=0; m<3; m++){
    18.       c2[l][m] = a_buffer[m];
    19.     }
    20.   }
    21.
    22. putsUSBUSART(c2);
    23.
    24. }
