PIC18F4550 ADC for infrared signal
Discussion in 'Embedded Systems and Microcontrollers' started by unoeusux, Jan 21, 2010.
  1. unoeusux
    Jan 20, 2010
    I am not too sure whether this will work, any one can help me? this program is suppose to record the highest signal level and location, go back to the infrared signal to shoot a target.:confused:
    #include <p18F4550.h>
    #include <delays.h>
    // Include this when using Bootloader Program ================================
    #pragma udata
    extern void _startup (void); // See c018i.c in your C18 compiler dir
    #pragma code _RESET_INTERRUPT_VECTOR = 0x000800
    void _reset (void)
    _asm goto _startup _endasm
    #pragma code
    #pragma code _HIGH_INTERRUPT_VECTOR = 0x000808
    void _high_ISR (void)
    #pragma code _LOW_INTERRUPT_VECTOR = 0x000818
    void _low_ISR (void)
    #pragma code
    #pragma code
    // additional codes ends here ===============================================================
    // Your program declarations start here:====
    unsigned char v_name;
    double Vmax = 0;
    double Vpre = 0;
    double V = 0;
    int Pmax = 0;
    int count = 0;
    int i = 0;
    main(void)
    // Do not remove these as well=============
    ADCON1 = 0x0F;
    CMCON = 0x07;
    // Your MAIN program Starts here: =========
    TRISAbits.TRISA0 = 1;
    TRISAbits.TRISA1 = 1;
    TRISCbits.TRISC0 = 0;
    TRISCbits.TRISC2 = 0;
    TRISB = 0b00000111;
    TRISD = 0x00;
    ADCON0 = 0b00000001; // AN0,IDLE,ON //Converting Comparing
    ADCON1 = 0b00001110; // Vref - 0v,5v , AN0 analog input$
    ADCON2 = 0b00000111; // left justified
    if(PORTBbits.RB0 == 0)
    CCP1CON = 0b00001100;
    PR2 = 29; //25khz, 40us
    CCPR1L = 0b00001001; // Generating 30% dutycycle Wave
    CCP1CONbits.DC1B1 = 0;
    CCP1CONbits.DC1B0 = 0;
    T0CON = 0b00000111;
    T2CON = 0b00000111;
    while(count < 124) // while duty cycle <=70%
    count ++;
    CCPR1L++;
    Delay1KTCYx(250);
    Delay1KTCYx(250);
    Delay1KTCYx(250);
    Delay1KTCYx(250);
    Delay1KTCYx(250);
    Delay1KTCYx(250);
    ADCON0bits.GO = 1;
    while(ADCON0bits.GO == 1)
    Vpre = ADRESH;
    if (Vpre >= Vmax)
    Vmax = Vpre;
    else
    i++;
    while(i>0)
    CCPR1L--;
    i--;
  2. unoeusux
    Jan 20, 2010
    any one? thanks in advance
