Thanks for the reply man . I'll give this a try and see how it goes.OK, so the problem right now is in the master.
Simplest thing first: do you have the I2C pull up resistors? 5K is typical. An unprogrammed (just bulk erase it) PIC should show these 2 pins as a high.
Next, your code master does one write to the slave then stops. It's much easier to see a periodic repeating signal. I would make my test master as such:
Toggling an unused pin while transmitting gives your scope a synch to use. It's also a nice sanity test.Rich (BB code):#include <p18f4520.h> #include <delays.h> #include <i2c.h> unsigned char i2cPutByteAndWait(unsigned char); char clearData = 0; void main(void) { char address_w = 0x98, result = 0, temp = 0; SSPSTAT = 0xC0; SSPCON1 = 0x28; SSPCON2 = 0x00; SSPADD = 0x09; TRISC = 0b00000000; // afaik the ports should be set as inputs // but OpenI2C does this for you. while(1) { OpenI2C(MASTER, SLEW_OFF); StartI2C(); IdleI2C(); WriteI2C(address_w & 0xFE); IdleI2C(); WriteI2C(0x01); IdleI2C(); SSPBUF = address_w; while(SSPSTATbits.BF); while((SSPCON2 & 0x1F) || (SSPSTAT & 0x04)); SSPCON2bits.PEN = 1; // StopI2C // add a delay here to break up transmissions on your scope } // while(SSPCON2bits.PEN == 1); }
(BTW, leaving the EEPROM would give you a 2nd slave to test the master's START/ADDR/STOP against. So it may have helped to have left it in.)
