PIC18F4520 assembly programe error.
Discussion in 'Embedded Systems and Microcontrollers' started by thar07, Sep 23, 2015.
  1. thar07
    Jan 3, 2015
    71
    i wrote this program to toggel the output of Port d in the proteus and it is running perfectly. But when i complied it with MPASMWIN it shows the following errors. Could you please tell me what wrong with this ?
    lst file
  2. GopherT
    Nov 23, 2012
    6,339
    4,083
    Register names are case sensitive. PORTB, TRISB
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    The assembler could not find the include file which defines things. This usually happens for one of two reasons:
    1. The include file "p18f4520inc" is not located in the folder where the assembler is looking for it, or
    2. The assembler has no idea where to look for the include file.
    What you need to do is review the documentation to find out how such things are done.
  4. thar07
    Jan 3, 2015
    71
    How to correct those errors ?
  5. Papabravo
    Feb 24, 2006
    10,340
    1,850
    How to correct those errors requires understanding what the assembler is trying to do. Understanding what the assembler is trying to do requires that you:
    "... review the documentation to find out how such things are done."
    which is what I told you in my previous post.
    In other words you must place the include file where the assembler can find it, or you must give the assembler the path to the folder where the include file is located.
  6. ErnieM
    Apr 24, 2011
    7,443
    1,628
    Once you get the path to your include files settled your next errors will come from your list of equates. At best these will produce warnings for delicate definitions, at worst they will yield hard errors. Best remove them and let the include file do that part of the heavy lifting.
    How are you using the assembler? It works easily inside MPLAB where setting like the device being used (which is in your list of errors) will be set for you when you walk thru the new project wizard.
    thar07 likes this.
  7. dannyf
    Sep 13, 2015
    2,196
    417
    Using assembly is preferred if you have lots of free time or free money, or you want to push the performance envelope.
    Otherwise, it is far better to code in C.
  8. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Who asked you for that pearl of wisdom?
  9. dannyf
    Sep 13, 2015
    2,196
    417
    For example, your asm code can be simply done in C as
    Code (Text):
    1.
    2.   OUT_PORT ^= OUT_MASK; // flip out_mask
    3.
    The code itself is quite self explanatory and will work for all mcus -> much more portable than your assembly.
