is this program good?
PORTA 2: the sensor input.
PORTA3 connect to PORTA0.
_______________________________________________________________________________________________________
This code is to read the values made from the sensor. Upper limit set. LED Lights up when it goes over the limit.
i'm open to suggestion
Rich (BB code):
list p=18f452
; Include file, change directory if needed
include "p18f452.inc"
; Start at the reset vector
Reset_Vector code 0x000
goto Start ; Start application beyond vector area
code 0x002A
Start
clrf PORTB ;Clear PORTB
clrf TRISB ;PORTB all outputs,
; A/D result on LEDs
movlw B'00010001' ;Fosc/8, A/D enabled
movwf ADCON0
movlw B'00001010' ;Left justify,2 analog channel
movwf ADCON1 ;Vres+ = 5mV
movlw B'11000111' ;TMR0 prescaler, 1:256
movwf T0CON
Main
btfss INTCON,TMR0IF ;Wait for Timer0 to timeout
goto Main
bcf INTCON,TMR0IF
bsf ADCON0,GO ;Start A/D conversion
Wait
btfss PIR1,ADIF ;Wait for conversion to complete
goto Wait
NOP
MOVFF ADRESH,WREG
MOVFF WREG,W
SUBLW B'11111111'
BNZ Less_than_5mv ;if <> 0xff, go less than 5mv
MOVFF ADRESL,WREG ;else
ANDLW 0x80
SUBLW 0x80
BNZ Less_than_5mv ;if <> 0xc0, go less than 5mv
GOTO Than_5mv ;otherwise, >5mv
Less_than_5mv
MOVFF W,WREG
NOP
ADDLW 0x00
ADDLW B'10011010' ;0x66 + 0x99 -> WREG
BZ Sub_P2 ;if Zero, go check Less or high than 2mv
BNC Less_2mv ;if no Carry, Less Than 2mv
GOTO Less_5mv_than_2mvS1
Sub_P2
MOVFF ADRESL,WREG
ADDLW 0x00
ANDLW 0xc0
ADDLW B'01000000'
BC Less_5mv_than_2mvS1
goto Less_2mv
Than_5mv
MOVLW B'00000100' ;RB2 ON
goto Disp_PB
Less_5mv_than_2mvS1
MOVLW B'00000010' ;RB1 ON
goto Disp_PB
Less_2mv
MOVLW B'00000001' ;RB0 ON
goto Disp_PB
Disp_PB
movwf PORTB ;Write A/D result to PORTB
clrf PORTB
WaitPush ;Pause while switch is pressed
btfss PORTA,4
goto WaitPush
movwf PORTB
goto Main ;Do it again
end
