I used this code:
everything works fine but not the LCD, it displays full blocks on the 1st line only, and not the conditions I wrote in the code
any help would be appreciated
I used this code:
Rich (BB code):
Device 18F452
XTAL 4
;LCD initialization
Declare LCD_DTPIN PORTB.4
Declare LCD_ENPIN PORTB.3
Declare LCD_INTERFACE 4
Declare LCD_RSPIN PORTB.2
Declare LCD_LINES 2
Declare LCD_TYPE = 0
cls
GoTo main
ASM
main:
;port A
clrf PORTA,access
clrf PORTA,access
setf TRISA,access
;port C
clrf PORTC,access
clrf LATC,access
clrf TRISC,access
;ADCON
movlw 0x81
movwf ADCON0,access
;T0con
movlw 0x07
movwf T0CON,access
again:
Call DELAY
;Start A/D
bsf ADCON0,2,access
;wait A/D
loop:
btfsc ADCON0,2,access
bra loop
;print temp
GoTo LCD1
check:
;check upper limit
movlw .138
cpfslt ADRESH,access
bra overheat
;check middle limit
movlw .103
bra cooling ;high temp
;check lower limit
movlw .69
cpfsgt ADRESH,access
bra heating ;low temp
;clear outputs 40-60
clrf PORTC,access
bra again
;cooling >60
cooling:
bsf PORTC,2,access
bcf PORTC,0,access
bra again
;heating <40
heating:
bsf PORTC,0,access
bcf PORTC,2,access
bra again
;overheat >80
overheat:
bsf PORTC,2,access
bsf PORTC,3,access
GoTo LCD2
;1s delay
DELAY:
clrf TMR0L,access
clrf TMR0H,access
bsf T0CON,7,access
movlw 0x42
wait2:
cpfsgt TMR0L,access
bra wait2
movlw 0x0f
cpfsgt TMR0H,access
bra wait2
bcf T0CON,7,access
Return
ENDASM
LCD1:
Cls
Print At 1,1,"Temp=",Dec ADRESH *150/255
DelayMS 500
bra check
LCD2:
Cls
Print At 1,1, "Temp=", Dec ADRESH *150/255
Print At 2,2,"OVERHEATING!!"
DelayMS 3000
bra again
