PIC18f4431 int1 and int2
Discussion in 'Embedded Systems and Microcontrollers' started by dmta, Sep 2, 2013.
  1. dmta
    Mar 24, 2013
    32
    Hi all,
    I am trying to configure the external interrupts int1 and int2 of a pic18f4431 without any success. The int0 and timer1 interrupts which are also running work just fine. Please look at my code and tell me what i am doing wrong.
    I am using miKroC pro for PIC
    Code ( (Unknown Language)):
    1. //******************************************************************************
    2. //LCD connections
    3. sbit LCD_RS at RD5_bit;
    4. sbit LCD_EN at RD4_bit;
    5. sbit LCD_D7 at RB5_bit;
    6. sbit LCD_D6 at RB2_bit;
    7. sbit LCD_D5 at RB0_bit;
    8. sbit LCD_D4 at RD6_bit;
    9.
    10. sbit LCD_RS_Direction at TRISD5_bit;
    11. sbit LCD_EN_Direction at TRISD4_bit;
    12. sbit LCD_D7_Direction at TRISB5_bit;
    13. sbit LCD_D6_Direction at TRISB2_bit;
    14. sbit LCD_D5_Direction at TRISB0_bit;
    15. sbit LCD_D4_Direction at TRISD6_bit;
    16. //******************************************************************************
    17. //functions
    18. void timer1_init();             // initialize TIMER1
    19. void inbuiltF_init();           // initialize inbuilt functions
    20. void interrupts_init();         // initialize interrupts
    21. void interrupt();
    22. void display_lcd();
    23. //******************************************************************************
    24. // global variables
    25. int calpid = 0;                 // pid loop run command
    26. int ledon  = 0;
    27. int x      = 0;
    28.
    29. //******************************************************************************
    30. void interrupt(){
    31.      if(PIR1.TMR1IF==1){
    32.           calpid = 1;           // run PID loop
    33.           TMR1L         = 181;  //// preload timer1
    34.           TMR1H         = 179;  ////
    35.           PIR1.TMR1IF = 0;
    36.      }
    37.      if(INTCON.INT0IF==1){
    38.           ledon = 1;
    39.           INTCON.INT0IF = 0;
    40.      }
    41.      if(INTCON3.INT1IF==1){
    42.           ledon = 1;
    43.           INTCON3.INT1IF==0;
    44.      }
    45.      if(INTCON3.INT2IF==1){
    46.           ledon = 1;
    47.           INTCON3.INT2IF==0;
    48.      }
    49. }
    50. //******************************************************************************
    51. void main(){
    52.
    53.      TRISC.F7 = 0;
    54.      PORTC.F7 = 0;
    55.      inbuiltF_init();
    56.      interrupts_init();
    57.      timer1_init();
    58. //******************************************************************************
    59.      while(1) {
    60.           while(ledon==1){
    61.                Lcd_Out(1,1,"led on");
    62.                Delay_ms(100);
    63.                Lcd_Out(1,1,"      ");
    64.                ledon = 0;
    65.           }
    66.           while(calpid==1){
    67.                x = x + 1;
    68.                if(x<128){
    69.                     PORTC.F7 = 1;
    70.                }
    71.                else if(x<512){
    72.                     PORTC.F7 = 0;
    73.                }
    74.                else if(x==512){
    75.                     x = 0;
    76.                }
    77.                calpid = 0;
    78.           }
    79.      }
    80. }
    81. //******************************************************************************
    82. void timer1_init(){                // initialized to give 256Hz interrupt for PID loop execution
    83.      TMR1L         = 181;          // preload timer1
    84.      TMR1H         = 179;
    85.
    86.      T1CON.RD16    = 1;          // enable register read/write of TIMER1 in two 16-bit operations[7](1)
    87.      T1CON.T1RUN   = 0;          // system clock is derived from another source                  [6](0)
    88.      T1CON.T1CKPS1 = 0;          // ##increments with 1:2 prescale value                         [5](0)
    89.      T1CON.T1CKPS0 = 1;          // ##                                                           [4](1)
    90.      T1CON.T1OSCEN = 0;          // TIMER1 oscillator is shut-off                                [3](0)
    91.      T1CON.TMR1CS  = 0;          // TIMER1 uses internal clock (FOSC/4)                          [1](0)
    92.      T1CON.TMR1ON  = 1;          // enable TIMER1                                                [0](1)
    93. }
    94. //******************************************************************************
    95. void inbuiltF_init(){
    96.      Lcd_Init();
    97.      Lcd_Cmd(_LCD_CLEAR);
    98.      Lcd_Cmd(_LCD_CURSOR_OFF);
    99. }
    100. //******************************************************************************
    101. void interrupts_init(){
    102.      RCON.IPEN   = 0;           // disable priority levels on interrupts         (0)
    103.
    104.      INTCON.GIE  = 1;           // global interrupts enabled                     (1)
    105.      INTCON.PEIE = 1;           // enable all unmasked peripheral interrupts     (1)
    106.
    107.      PIE1.TMR1IE = 1;           // TIMER1 overflow interrupt enabled             (1)
    108.      IPR1.TMR1IP = 0;           // TIMER1 overflow interrupt set to low priority (0)
    109.      PIR1.TMR1IF = 0;           // clear TIMER1 overflow interrupt flag          (0)
    110.
    111.
    112.      INTCON.INT0IE   = 1;       // RC3 external interrupt enable                 (1)
    113.      INTCON2.INTEDG0 = 1;       // external interrupt0 RC3 on rising edge        (1)
    114.      INTCON.INT0IF   = 0;       // clear RC3 INT0 interrupt flag
    115.
    116.      INTCON3.INT1IP  = 0;       // INT1 external interrupt priority - low        (0)
    117.      INTCON2.INTEDG1 = 1;       // external interrupt1 RC4 on rising edge
    118.      INTCON3.INT1IF  = 0;       // clear RC4 INT1 interrupt flag
    119.      INTCON3.INT1IE  = 1;       // RC4 external interrupt enable
    120.
    121.      INTCON3.INT2IP  = 0;       // INT2 external interrupt priority - low         (0)
    122.      INTCON2.INTEDG2 = 1;       // external interrupt2 RC5 on rising edge
    123.      INTCON3.INT2IF  = 0;       // clear RC5 INT2 interrupt flag
    124.      INTCON3.INT2IE  = 1;       // RC5 external interrupt enable
    125. }
    regards
  2. joeyd999
    Jun 6, 2011
    2,756
    2,923
    2.           ledon = 1;
    4.      }
    6.           ledon = 1;
    8.      }
    9.
    Perhaps you should set the interrupt flags to 0 rather than compare them with 0?
    dmta likes this.
  3. dmta
    Mar 24, 2013
    32
    That was IT. Thank you !!!!!!!!!!!!!!!!!!!!11
  4. ErnieM
    Apr 24, 2011
    7,436
    1,625
    I've seen many references in C style guides that one should always do comparisons with the constant on the left, as this WILL cause an error when the == is replaced by a single =
    if (12 == A) // valid
    if (12 = A) // always invalid
    However... I don't see anything that would guard against this sort of typo. A second pair of eyeballs is a very effective tool. However, code walking with a simulator or a debugger will find this and many more bugs.
  5. THE_RB
    Feb 11, 2008
    5,435
    1,305
    I'm pretty sure that same compiler generates a warning message at the bottom of the screen for this plain assignment;
    register == constant;
    but dmta may have that panel at the screen bottom closed when compiling. It's the same panel that shows the build results.
