This is some help for your problems reported in a PM
#pragma config CONFIG5L = 0xF
#pragma config CONFIG5H = 0xff
#pragma config CONFIG6L = 0xff
#pragma config CONFIG6H = 0xff
#pragma config CONFIG7L = 0xff
#pragma config CONFIG7H = 0xff
#pragma config CONFIG5H = 0xC0
#pragma config CONFIG6L = 0xF
#pragma config CONFIG6H = 0xE0
#pragma config CONFIG7L = 0xF
#pragma config CONFIG7H = 0x40
That was just warnings Some of the fusebits in these config words are not used. And hence you can write to themWith reference to the attachment in the previous post.
I had to change the last part of the configuration bits from:
To:Rich (BB code):#pragma config CONFIG5L = 0xF #pragma config CONFIG5H = 0xff #pragma config CONFIG6L = 0xff #pragma config CONFIG6H = 0xff #pragma config CONFIG7L = 0xff #pragma config CONFIG7H = 0xff
Now it compiles without any errors.Rich (BB code):#pragma config CONFIG5L = 0xF #pragma config CONFIG5H = 0xC0 #pragma config CONFIG6L = 0xF #pragma config CONFIG6H = 0xE0 #pragma config CONFIG7L = 0xF #pragma config CONFIG7H = 0x40
Thanks.
Consider yourself warnedI'd like my code to compile completely without warnings. Then I know everything is OK. Or at least it compiles OK.
Thread starter | Similar threads | Forum | Replies | Date |
PIC18F25K22 & ADC problem | Microcontrollers | 4 |
Similar threads |
by Jake Hertz
by Jake Hertz
by Aaron Carman
