pic18f2321 reset vector wont build
Discussion in 'Embedded Systems and Microcontrollers' started by Dodgydave, Jul 19, 2013.
  1. Dodgydave
    Thread Starter AAC Fanatic!
    Jun 22, 2012
    5,166
    776
    I am having trouble with a template in mpasm, it just wont build if i put the reset vector in like it says
    org 0x000
    goto main
    i get these errors , so what is wrong???
    Error[113] C:\PIC_PROGS\18F2321TEST.ASM 86 : Symbol not previously defined (main)
    Error[118] C:\PIC_PROGS\18F2321TEST.ASM 86 : Overwriting previous address contents (0000)
    Error[118] C:\PIC_PROGS\18F2321TEST.ASM 86 : Overwriting previous address contents (0001)
    Error[118] C:\PIC_PROGS\18F2321TEST.ASM 86 : Overwriting previous address contents (0002)
    Error[118] C:\PIC_PROGS\18F2321TEST.ASM 86 : Overwriting previous address contents (0003)
    Halting build on first failure as requested.
  2. MaxHeadRoom
    Jul 18, 2013
    10,862
    2,525
    Well the first I would say is that you do not have a label 'main' or you have assigned it as 'Main' (capital M)?
    Which of the two templates are you using?
    Max.
  3. JohnInTX
    Jun 26, 2012
    2,394
    1,051
    Something, probably the template, has generated code at 0000h prior to your ORG. Your ORG resets the PC to 0000 and is clobbering that code. Search the .lst file for ORG and 0000 in the address field of the listing.
  4. t06afre
    May 11, 2009
    5,939
    1,222
    Show us your code
  5. Dodgydave
    Jun 22, 2012
    5,166
    776
    Fixed it, the reset vector was after the config set up. Doh!
