Hello everybody. I was hoping that you could help me with a problem I'm having. I was programming a PIC perfectly until I started getting the following message. It seems to be a problem in the configuration bits. Have any of you had a similar problem before. I tried searching online, but didn't find information.
Connecting to MPLAB PICkit 3...
Firmware Suite Version.....01.27.15
Firmware type..............PIC18F
Target detected
Device ID Revision = a
The following memory area(s) will be programmed:
program memory: start address = 0x0, end address = 0x1ff
configuration memory
Programming...
Address: 300006 Expected Value: 81 Received Value: 85
Failed to program device
Target detected
Programming...
