PIC18F1220 Build Error
Discussion in 'Embedded Systems and Microcontrollers' started by tyc8159, Dec 6, 2006.
  1. tyc8159
    Dec 6, 2006
    6
    I builded this codes,
    PROCESSOR PIC18F1220
    RADIX HEX
    ; Enhancing the CCP/ECCP frequency resolution for lighting applications
    ; This technique allows a very high frequency PWM (100kHz) signal to be generated
    ; while providing extremely small frequency increments (60Hz)
    INCLUDE "p18f1220.inc"
    ; timing definitions in kH
    #define CLOCK .10000 ; Tcy = 40MHz/4 = 10MHz
    #define NFREQ .100 ; nominal frequency 100kHz
    #define IPERIOD (CLOCK/NFREQ)-1 ; calculating the base period
    #define IFRAC .5 ; 4 bit(0-15)augmented resolution
    ; RAM allocation
    CBLOCK 0
    PERIOD ; integer period
    FRAC ; fractional period (0-15)
    FACC ; fractional accumulator
    ENDC
    ; port definitions
    #define OUT PORTB,0 ; for demonstration only
    ORG 0 ; reset vector
    resetv
    goto init
    ORG 08 ; high priority interrupt vector
    isr
    bcf CCP1CON,DC1B1
    bcf PIR1,TMR2IF ; clear the interrupt flag
    movf FRAC,W
    addwf FACC,F ; add the FRAC to the accumulator
    movf PERIOD,W ; get the base period value in W
    btfss FACC,4 ; if there was a carry in the fractional accumulator
    goto setpr2
    incf WREG,W ; increase the period by 1
    bsf CCP1CON,DC1B1 ; increase duty by 2xTq to keep it 50%
    setpr2
    movwf PR2 ; update the next period value
    ; <<< for demonstration only
    btfsc FACC,4
    bsf OUT ; signal longer period (T1)
    btfss FACC,4
    bcf OUT ; signal shorter period (T2)
    ; >>> for demonstration only
    bcf FACC,4 ; clear the carry bit
    isre
    retfie 1 ; return (fast) restoring the shadow registers
    ; total ISR time = 13 cycles or 13% MCU load @100kHz/40MHz
    setPWM
    ; save the required PWM period value
    movwf PERIOD
    ; set the initial period register value PR2
    movwf PR2
    ; set the duty cycle to 50%
    incf WREG,W ; PERIOD+1 is the actual total cycle count
    bcf STATUS,C ; divide by 2
    rrcf WREG,F ; shifting right
    movwf CCPR1L ; set the duty cycle
    return
    init
    ; init the output port
    movlw b'00000000'
    movwf TRISB
    ; disable analog inputs
    setf ADCON1
    ; set CCP module in PWM mode
    movlw b'00001100'
    movwf CCP1CON
    ; set the tmr2 to generate the desired frquency and 50% duty
    movlw b'00000100' ; prescale 0, postscale 0, tmr2 ON
    movwf T2CON
    ; init the period value
    movlw IPERIOD
    call setPWM ; set the PWM and duty cycle
    ; then init the FRACTIONAL divider for the demo
    movlw IFRAC
    movwf FRAC ; init the fractional period part
    ; clear the fractional accumulator
    clrf FACC ; clear the accumulator
    ; then init the interrupt on CCP1/TMR2
    bcf PIR1,TMR2IF
    bsf PIE1,TMR2IE
    ; init gloabal and peripheral interrupts
    bsf INTCON,PEIE
    bsf INTCON,GIE
    main
    goto main
    end
    and i got the error:
    Clean: Deleting intermediary and output files.
    Clean: Deleted file "C:\Projects32\mytest.o".
    Clean: Deleted file "C:\Projects32\mytest.ERR".
    Clean: Deleted file "mytest.lst".
    Clean: Done.
    Executing: "C:\Program Files\Microchip\MPASM Suite\MPAsmWin.exe" /q /p18F1220 "mytest.asm" /l"mytest.lst" /e"mytest.err" /o"mytest.o"
    Warning[205] C:\PROJECTS32\MYTEST.ASM 1 : Found directive in column 1. (PROCESSOR)
    Warning[205] C:\PROJECTS32\MYTEST.ASM 2 : Found directive in column 1. (RADIX)
    Warning[205] C:\PROJECTS32\MYTEST.ASM 8 : Found directive in column 1. (INCLUDE)
    Warning[205] C:\PROJECTS32\MYTEST.ASM 17 : Found directive in column 1. (CBLOCK)
    Warning[205] C:\PROJECTS32\MYTEST.ASM 21 : Found directive in column 1. (ENDC)
    Warning[205] C:\PROJECTS32\MYTEST.ASM 26 : Found directive in column 1. (ORG)
    Warning[203] C:\PROJECTS32\MYTEST.ASM 28 : Found opcode in column 1. (goto)
    Warning[205] C:\PROJECTS32\MYTEST.ASM 30 : Found directive in column 1. (ORG)
    Warning[203] C:\PROJECTS32\MYTEST.ASM 32 : Found opcode in column 1. (bcf)
    Warning[203] C:\PROJECTS32\MYTEST.ASM 33 : Found opcode in column 1. (bcf)
    Warning[203] C:\PROJECTS32\MYTEST.ASM 34 : Found opcode in column 1. (movf)
    Warning[203] C:\PROJECTS32\MYTEST.ASM 35 : Found opcode in column 1. (addwf)
    Warning[203] C:\PROJECTS32\MYTEST.ASM 36 : Found opcode in column 1. (movf)
    Warning[203] C:\PROJECTS32\MYTEST.ASM 37 : Found opcode in column 1. (btfss)
    Warning[203] C:\PROJECTS32\MYTEST.ASM 38 : Found opcode in column 1. (goto)
    Warning[203] C:\PROJECTS32\MYTEST.ASM 39 : Found opcode in column 1. (incf)
    Warning[203] C:\PROJECTS32\MYTEST.ASM 40 : Found opcode in column 1. (bsf)
    Warning[203] C:\PROJECTS32\MYTEST.ASM 42 : Found opcode in column 1. (movwf)
    Warning[203] C:\PROJECTS32\MYTEST.ASM 44 : Found opcode in column 1. (btfsc)
    Warning[203] C:\PROJECTS32\MYTEST.ASM 45 : Found opcode in column 1. (bsf)
    Warning[203] C:\PROJECTS32\MYTEST.ASM 46 : Found opcode in column 1. (btfss)
    Warning[203] C:\PROJECTS32\MYTEST.ASM 47 : Found opcode in column 1. (bcf)
    Warning[203] C:\PROJECTS32\MYTEST.ASM 49 : Found opcode in column 1. (bcf)
    Warning[203] C:\PROJECTS32\MYTEST.ASM 51 : Found opcode in column 1. (retfie)
    Warning[203] C:\PROJECTS32\MYTEST.ASM 56 : Found opcode in column 1. (movwf)
    Warning[203] C:\PROJECTS32\MYTEST.ASM 58 : Found opcode in column 1. (movwf)
    Warning[203] C:\PROJECTS32\MYTEST.ASM 60 : Found opcode in column 1. (incf)
    Warning[203] C:\PROJECTS32\MYTEST.ASM 61 : Found opcode in column 1. (bcf)
    Warning[203] C:\PROJECTS32\MYTEST.ASM 62 : Found opcode in column 1. (rrcf)
    Warning[203] C:\PROJECTS32\MYTEST.ASM 63 : Found opcode in column 1. (movwf)
    Warning[203] C:\PROJECTS32\MYTEST.ASM 64 : Found opcode in column 1. (return)
    Warning[203] C:\PROJECTS32\MYTEST.ASM 68 : Found opcode in column 1. (movlw)
    Warning[203] C:\PROJECTS32\MYTEST.ASM 69 : Found opcode in column 1. (movwf)
    Warning[203] C:\PROJECTS32\MYTEST.ASM 71 : Found opcode in column 1. (setf)
    Warning[203] C:\PROJECTS32\MYTEST.ASM 73 : Found opcode in column 1. (movlw)
    Warning[203] C:\PROJECTS32\MYTEST.ASM 74 : Found opcode in column 1. (movwf)
    Warning[203] C:\PROJECTS32\MYTEST.ASM 76 : Found opcode in column 1. (movlw)
    Warning[203] C:\PROJECTS32\MYTEST.ASM 77 : Found opcode in column 1. (movwf)
    Warning[203] C:\PROJECTS32\MYTEST.ASM 79 : Found opcode in column 1. (movlw)
    Warning[203] C:\PROJECTS32\MYTEST.ASM 80 : Found opcode in column 1. (call)
    Warning[203] C:\PROJECTS32\MYTEST.ASM 82 : Found opcode in column 1. (movlw)
    Warning[203] C:\PROJECTS32\MYTEST.ASM 83 : Found opcode in column 1. (movwf)
    Warning[203] C:\PROJECTS32\MYTEST.ASM 85 : Found opcode in column 1. (clrf)
    Warning[203] C:\PROJECTS32\MYTEST.ASM 87 : Found opcode in column 1. (bcf)
    Warning[203] C:\PROJECTS32\MYTEST.ASM 88 : Found opcode in column 1. (bsf)
    Warning[203] C:\PROJECTS32\MYTEST.ASM 90 : Found opcode in column 1. (bsf)
    Warning[203] C:\PROJECTS32\MYTEST.ASM 91 : Found opcode in column 1. (bsf)
    Warning[203] C:\PROJECTS32\MYTEST.ASM 94 : Found opcode in column 1. (goto)
    Warning[205] C:\PROJECTS32\MYTEST.ASM 95 : Found directive in column 1. (end)
    Executing: "C:\Program Files\Microchip\MPASM Suite\MPLink.exe" "C:\Projects32\18f1220.lkr" "C:\Projects32\mytest.o" /o"pwmtest.cof" /M"pwmtest.map"
    MPLINK 4.06, Linker
    Copyright (c) 2006 Microchip Technology Inc.
    Error - section '.org_1' can not fit the absolute section. Section '.org_1' start=0x00000008, length=0x00000056
    Errors : 1
    BUILD FAILED: Thu Dec 07 00:06:35 2006
    Can anyone help me in that? Appreciate
  2. n9352527
    Oct 14, 2005
    1,198
    You need to put a tab or a space before each directive (opcode line). After, post again if you still get the org linker error.
  3. tyc8159
    Dec 6, 2006
    6
    Hi all,
    i still got the same error message after i put a space/tab before each opcode line:confused: . Is anyone know what happended there? i use the linker script 18f1220.lkr
    thanks for everyone that help me in that.
  4. n9352527
    Oct 14, 2005
    1,198
    Are the error messages identical with the one you posted earlier? If not post the messages again.
    All those 'found directive/opcode in column 1' errors are because there are no tabs/spaces before the opcodes/directives.
    That linker error is because there is a program section that doesn't fit available mapping memory section.
    I suggested to get rid of the syntax errors first, then proceed from there.
