PIC18 .asm Switch Construct
Discussion in 'Embedded Systems and Microcontrollers' started by joeyd999, Dec 31, 2014.
  1. joeyd999
    Thread Starter AAC Fanatic!
    Jun 6, 2011
    2,756
    2,922
    I know you all are using C to program PIC18s these days, but I am still crunching along writing awesome code in .asm on a daily basis -- and loving every minute of it.
    I came up with a neat new trick today -- out of necessity -- and I wanted to share.
    Suppose you had a number of subroutines, and you wanted to call one (and only one!) of them based upon an index value. The 'C' equivalent would be:
    Code (Text):
    1.
    2. switch (index)
    3. {
    4.     case 0: routine0(); break;
    5.     case 1: routine1(); break;
    6.     ...
    7.     case n: routinen(); break;
    8. }
    9.
    In .asm, you'd normally do something like this:
    Code (Text):
    1.
    2.     movlw    high jtab    ;ensure jump in page
    3.     movwf    pclath
    4.
    5.     rlncf    index,w        ;double index
    6.     addwf    pcl,f        ;and make computed jump
    7.
    8. jtab    bra    vect0        ;vector to call for specified routine
    9.     bra    vect1
    10.     ...
    11.     bra    vectn
    12.
    13. vect0    call    routine0    ;and make the call
    14.     bra    jdone        ; "break" equivalent
    15. vect1    call    routine1
    16.     bra    jdone
    17.     ...
    18. vectn    call    routinen
    19.     bra    jdone
    20.
    21. jdone                ;finished
    22.
    There are a couple of things I don't like about this. First, the need to ensure pclath points to the proper page -- and the associated problem of ensuring that all destinations within the jump table are within that page -- gets annoying after a while. I previously solved this issue with another trick, a routine called CJUMP, detailed here. Using CJUMP, the code reduces to the following:
    Code (Text):
    1.
    2.     movf    index,w        ;get index in wreg
    3.     call    cjump        ;and jump to indexed vector
    4.
    5.     bra    vect0        ;vector to call for specified routine
    6.     bra    vect1
    7.     ...
    8.     bra    vectn
    9.
    10. vect0    call    routine0    ;and make the call
    11.     bra    jdone        ; "break" equivalent
    12. vect1    call    routine1
    13.     bra    jdone
    14.     ...
    15. vectn    call    routinen
    16.     bra    jdone
    17.
    18. jdone                ;finished
    19.
    This is a bit better, as I no longer need to deal with PCLATH or worry about my jump table spanning page boundaries. But, I still have *two* tables. Can I reduce this to one simple table? Yes!
    First, I want it to be possible that my subroutines may be anywhere in the address space, so I must use either CALLs or GOTOs, not RCALLs or BRAs. So I changed my CJUMP routine as follows:
    Code (Text):
    1.
    2. ;****************************************
    3. ;** CJUMP2 -- Preform a computed jump  **
    4. ;**           over 2 word instructions **
    5. ;****************************************
    6. ;**   w = index (0 to 63)              **
    7. ;****************************************
    8.
    9. cjump2    rlncf    wreg,f
    10.
    11. ;********************************************
    12. ;** CJUMP -- Preform a computed jump       **
    13. ;**          over single word instructions **
    14. ;********************************************
    15. ;**   w = index (0 to 127)                 **
    16. ;********************************************
    17.
    18. cjump    rlncf    wreg,f
    19.
    20.     addwf    tosl,f
    21.     skpnc
    22.     incf    tosh,f
    23.
    24.     return
    25.
    I've now got two options: a computed jump into either a table of single word instructions or a table of double word instructions (CJUMP2). Using this, I can try something like:
    Code (Text):
    1.
    3.     call    cjump2        ;and jump to indexed vector
    4.
    5.     call    routine0    ;and make the call
    6.     call    routine1
    7.     ...
    8.     call    routinen
    9.
    10. jdone                ;finished
    11.
    But this is not correct. If the index is 0, routine0, routine1, and all the subsequent routines will be executed. I only want routine0 called, followed by a branch to JDONE. What to do?
    Using the PIC18 PUSH instruction, I can preset the return stack to point to anywhere I like. If I set it to JDONE prior to indexing in the table, and use GOTOs instead of CALLs in the table, then I get what I desire:
    Code (Text):
    1.
    2.     push            ;create a new stack entry
    3.     movlw    high jdone    ;copy return address to stack
    4.     movwf    tosh
    5.     movlw    low jdone
    6.     movwf    tosl
    7.
    8.     movf    index,w        ;get index in wreg
    9.     call    cjump2        ;and jump to indexed vector
    10.
    11.     goto    routine0    ;and make the call
    12.     goto    routine1
    13.     ...
    14.     goto    routinen
    15.
    16. jdone                ;upon RETURN, each routine ends up here
    17.
    Further, I can simplify with a macro:
    Code (Text):
    1.
    2. switch    macro    idxreg,retaddr
    3.
    4.     push            ;create a new stack entry
    5.     movlw    high retaddr    ;copy return address to stack
    6.     movwf    tosh
    7.     movlw    low retaddr
    8.     movwf    tosl
    9.
    10.     movf    idxreg,w    ;get index in wreg
    11.     call    cjump2        ;and jump to indexed vector
    12.
    13.     endm
    14.
    15.
    For final code that looks like this:
    Code (Text):
    1.
    2.     switch    index,jdone    ;index to routine, exit at jdone
    3.
    4.     goto    routine0    ;and make the call
    5.     goto    routine1
    6.     ...
    7.     goto    routinen
    8.
    9. jdone                ;upon RETURN, each routine ends up here
    10.
    Short, sweet, easy to read. I thought this was pretty neat. Comments welcome.
    PS -> Why does this new editor turn my tabs into spaces?!!!!!
  2. NorthGuy
    Jun 28, 2014
    611
    121
    Or you can read the table with TBLRD. You fit 16-bit jump addresses into consecutive instructions. You'll need one instruction per address as opposed to 2 instructions for GOTOs. Assuming the table is at address JUMPADDR in program memory, and ignoring "U" bytes (as you did):
    Code (Text):
    1.
    2. movwf TBLPTRL
    3. rlncf TBLPTRL
    4. clrf TBLPTRH
    5. movlw JUMPADDR_H
    6. addwf TBLPTRH, f
    7. movlw JUMPADDR_L
    8. addwfc TBLPTRL, f
    9.
    10. push
    11. tblrd*+
    12. movwf TOSL
    13. tblrd*+
    14. movwf TOSH
    15. return
    16.
    Will run a little bit faster and will use only half of the memory compared to GOTOs. Easily expandable to higher indices too.
  3. joeyd999
    Jun 6, 2011
    2,756
    2,922
    Um, yea. That's an alternative to the computed goto -- of which there are many alternatives. But that wasn't the point of my post.
    I have proposed what I think is an elegant solution to a C style switch statement (with successive index and breaks at the end of each case) that is concise and easy to read and maintain in .asm.
