pic16f887 and lcd assembly code problem
Discussion in 'Embedded Systems and Microcontrollers' started by ian123, Feb 24, 2012.
  1. ian123
    Aug 24, 2011
    73
    please help with a problem i am having with my programmimng in assembly
    i have programmed the pic to display a 2 x16 lcd .using easypic 3 development board.
    when it is programmed the cpu is reset and the display shows 2 lines but the moment i push the hardware reset button the display goes to one line and shows the display in one line. ie it is as if it is not initialising the two line mode.
