PIC16F88 Interfacing with LED MATRIX
Discussion in 'The Projects Forum' started by Mohit Mayank, Mar 3, 2015.
  1. Mohit Mayank
    Mar 3, 2015
    Hi, I am trying to interface PIC16F88 with 8x8 LED MATRIX, using 4017 and ULN2803. My aim is to built a binary clock, and before directly jumping to hardware I thought of doing the simulation on Proteus 8.1 .
    So I interfaced the components and wrote the Embedded C program for the binary clock and tried to run the simulation on my computer, which as you have already guessed, didn't worked.
    The main problem is ULN2803, it is not sinking current(i.e. there is no current flow on the right side of ULN2803)
    Can Anyone please look at my circuit and tell me whats the problem there.
    Thank you.
  2. Dodgydave
    Jun 22, 2012
    5,166
    775
    You have no ground connection on pin 9.
  3. Mohit Mayank
    Mar 3, 2015
    of ULN?? But it is not showing, so I thought it was automatically connected to ground. Am I wrong?
  4. Dodgydave
    Jun 22, 2012
    5,166
    775
    the Uln wont work without a ground connection to 0v.
  5. Mohit Mayank
    Mar 3, 2015
    Hey, I am using Proteus, and when I click on ULN2803 and see the hidden pins, its says pin9 is connected to GND. Is it enough? If not then can you please guide me, to fix this.
  6. Dodgydave
    Jun 22, 2012
    5,166
    775
    i dont use simulation software, i build circuits to work on PCBs, the ic doesn't have a power supply, so i cant see how it can work?
  7. absf
    Dec 29, 2010
    1,493
    374
    Just add resistor pack like the attached to the output of ULN and set the property to 'digital' then it should work.
    Allen
    Mohit Mayank likes this.
  8. Flare_Guy
    Nov 18, 2012
    13
    Pin 10 (COM) needs to be tied to V+
  9. Mohit Mayank
    Mar 3, 2015
    ULN is finally working, thank you
  10. #12
    Nov 30, 2010
    16,705
    7,358
    The differences between simulating and real circuits seems so very strange!
    A, "real" circuit does not need a, "respak-7" (because R1 to R8 take care of that) but the ULN package needs a ground.
    In simulation, you have to add unnecessary resistors and the grounds are, "provided"?
    I'm so old that this makes my head hurt.
