hi im using a pic16f88 im using the ccp module in capture mode ,i want to measure the pulsewidht of a incoming signal the range is 30khz and 40khz
Ts = 30us to about 20us
my setup is
ccpcon1=0x05 // capture mode every rising edge
my CCPIE bit is set my GIE bit is set
T1CON=0x01;
the ccpr1 register consists of ccpr1l and ccpr1h , 2 8bit registers
the capture data will be present in the ccpr1 register
can someone show me how to write a interrupt routine on how to read this value from the ccpr1 register i want to use this value in my main program
thanks in advanced
my setup is
T1CON=0x01;
thanks in advanced
