Pic16f877a
Discussion in 'Programmer's Corner' started by wailoon86, Sep 12, 2007.
  1. wailoon86
    Sep 12, 2007
    Hi guys.
    I'm new to this website.
    Well, I'm basically trying to light up an LED with PIC16F877A using CCS C compiler.
    Is my code make sense?
    Thanks for your help.
    #include <16F877A.H>
    #use delay(clock=20000000)
    #fuses hs,nowdt,noprotect
    void main()
    set_tris_d(0b00000000);
    for(;;)
    output_high(PIN_B0);
    delay_ms(1000);
    output_low(PIN_B0);
    delay_ms(1000);
  2. Art
    Distinguished Member
    Sep 10, 2007
    797
    61
    I'm not used to pic C, but i tlook about right.
    Does it not work?
  3. nanovate
    May 7, 2007
    665
    Code ( (Unknown Language)):
    1. #include <16F877A.H>
    2. #use delay(clock=20000000)
    3. #fuses hs,nowdt,noprotect
    4.
    5. void main()
    6. {
    7. set_tris_d(0b00000000);
    8. for(;
    9. {
    10. output_high(PIN_B0);
    11. delay_ms(1000);
    12. output_low(PIN_B0);
    13. delay_ms(1000);
    14. }
    15. }
    Should set_tris_d() be set_tris_b()?
    And you can use the CODE tags to make it more readable ;)
