pic16f877a timer question ccs compiler
Discussion in 'Embedded Systems and Microcontrollers' started by thedarkotaku, Feb 6, 2013.
  1. thedarkotaku
    Feb 28, 2011
    7
    i have two questions for anyone on this forum. i've got a 6 7 segment count up clock circuit controlled by a pic16f877a and i was wondering how i would alter the code to get it to count down instead:
    Code ( (Unknown Language)):
    1.
    2. #include <16F877A.h>
    3. #fuses xt,NOWDT,PUT,NOBROWNOUT,NOLVP
    4. #use delay(clock = 4000000)
    5. #byte PORTA=0X05
    6. #byte PORTC=0x07
    7. #byte PORTB=0X06
    8. #byte PORTE=0x05
    9. #byte PORTD=0x08
    10. #define A0 PIN_A0
    11. #define A1 PIN_A1
    12. #define A2 PIN_A2
    13. #define A3 PIN_A3
    14. #define A4 PIN_A4
    15. #define A5 PIN_A5
    16.
    17.
    18.  int sec1,sec2,min1,min2,hour1,hour2;
    19.
    20. int counter=125;
    21. int flag=0;
    22.
    23.
    24. const int table[10]={0b00111111,
    25.             0b00000110,
    26.             0b01011011,
    27.             0b01001111,
    28.             0b01100110,
    29.             0b01101101,
    30.             0b01111101,
    31.             0b00000111,
    32.             0b01111111,
    33.                0b01100111};
    34.
    35.
    36.
    37.
    38. void main()
    39. {
    40. PORTB=0X00;
    41. PORTC=0X00;
    42.
    43. set_tris_e(0xff);
    44. set_tris_a(0xff);
    45. set_tris_c(0x00);
    46. set_tris_b(0x00);
    47. set_RTCC(6);
    48. setup_counters(RTCC_INTERNAL,RTCC_DIV_32);
    49. enable_interrupts(GLOBAL);
    50.
    51.
    52. for(;;)
    53. {
    54. PORTB=table[sec1];
    55. PORTC=0X01;
    56. delay_ms(2);
    57.
    58. PORTB=table[sec2];
    59. PORTC=0x02;
    60. delay_ms(2);
    61.
    62. PORTB=table[min1];
    63. PORTC=0x04;
    64. delay_ms(2);
    65.
    66. PORTB=table[min2];
    67. PORTC=0x08;
    68. delay_ms(2);
    69.
    70. PORTB=table[hour1];
    71. PORTC=0x10;
    72. delay_ms(2);
    73.
    74. PORTB=table[hour2];
    75. PORTC=0x20;
    76. delay_ms(2);
    77.
    78.
    79.
    80.
    81. if(flag==1){
    82.
    83.
    84.             flag=0;
    85.             }
    86.
    87.
    88.
    89.
    90.
    91.
    92. if(input(A0)==0)
    93.         {
    94.               disable_interrupts(INT_RTCC);
    95.              if(input(A1)==0){
    96.                              delay_ms(250);
    97.                             if(++min1>9)       {
    98.                                 min1=0;
    99.
    100.                                            if(++min2>5)  {
    101.                                                 min2=0;
    102.                                                          }
    103.                                                }
    104.
    105.                            }
    106.              if(input(A2)==0){
    107.                                             delay_ms(250);
    108.                                              if( ++hour1>9 ){
    109.                                                          hour1=0;
    110.                                                          ++hour2;
    111.                                                             }
    112.                                                if( (hour2==2) & (hour1>3) )  {
    113.        sec1=0;
    114.        sec2=0;
    115.        min1=0;
    116.        min2=0;
    117.        hour1=0;
    118.        hour2=0;
    119.        }
    120.
    121.                            }
    122.           }
    123. else if(input(A0)==1){
    124.             enable_interrupts(INT_RTCC);
    125.                }
    126.     }
    127.  }
    128.
    129.
    130. }
    131.
    132.
    133. #int_RTCC
    134. void microII()
    135.
    136. {                            //void switch_time();
    137. if(--counter>0)return;
    138. counter=125;
    139. flag=1;
    140.
    141.
    142. if(++sec1>9){
    143.    sec1=0;
    144.
    145.    if(++sec2>5){
    146.        sec2=0;
    147.
    148.        if(++min1>9){
    149.            min1=0;
    150.
    151.             if(++min2>5){
    152.                 min2=0;
    153.                                       if( ++hour1>9 )
    154.                                                             {
    155.                                                          hour1=0;
    156.                                                          ++hour2;
    157.                                                             }
    158.                                                if( (hour2==2) & (hour1>3) )  {
    159.        sec1=0;
    160.        sec2=0;
    161.        min1=0;
    162.        min2=0;
    163.        hour1=0;
    164.        hour2=0;
    165.        }
    166.
    167.             }
    168.                          }
    169.                      }
    170.                 }
    171.            }
    172.
    and also, i've been trying to get something else integrated into it , it would drive a bargraph led, but everytime i try to put it into this code, the timer will not light up or will flicker and go out. any suggestions, as i want to be able to have the bargraph animate while the timer is counting, and not be animated when its not counting. thanks for any help guys. oh and heres the bargraph portion of the code:
    1.
    3. #fuses HS,NOWDT,PUT,NOBROWNOUT,NOLVP
    5. #byte PORTD=0X08
    6. #byte PORTE=0x05
    7.
    8. void main()
    9. {
    10. while(1){
    11. PORTD = 0xff;
    12. PORTE = 0X00;
    13. set_tris_D(0x00);
    14. set_tris_E(0x00);
    15.
    16.
    17. PORTD=0b000000000;
    18. PORTE=0X00;
    19. delay_ms(50);
    20. PORTD=0b010000000;
    21. PORTE=0X00;
    22. delay_ms(50);
    23. PORTD=0b011000000;
    24. PORTE=0X00;
    25. delay_ms(50);
    26. PORTD=0b011100000;
    27. PORTE=0X00;
    28. delay_ms(50);
    29. PORTD=0b011110000;
    30. PORTE=0X00;
    31. delay_ms(50);
    32. PORTD=0b011111000;
    33. PORTE=0X00;
    34. delay_ms(50);
    35. PORTD=0b011111100;
    36. PORTE=0X00;
    37. delay_ms(50);
    38. PORTD=0b011111110;
    39. PORTE=0X00;
    40. delay_ms(50);
    41. PORTD=0b011111111;
    42. PORTE=0X00;
    43. delay_ms(50);
    44. PORTD=0b011111111;
    45. PORTE=0X00;
    46. delay_ms(50);
    47. PORTD=0b011111110;
    48. PORTE=0X00;
    49. delay_ms(50);
    50. PORTD=0b011111100;
    51. PORTE=0X00;
    52. delay_ms(50);
    53. PORTD=0b011111000;
    54. PORTE=0X00;
    55. delay_ms(50);
    56. PORTD=0b011110000;
    57. PORTE=0X00;
    58. delay_ms(50);
    59. PORTD=0b011110000;
    60. delay_ms(50);
    61. PORTE=0X00;
    62. PORTD=0b011111000;
    63. PORTE=0X00;
    64. delay_ms(50);
    65. PORTD=0b011111100;
    66. PORTE=0X00;
    67. delay_ms(50);
    68. PORTD=0b011111000;
    69. PORTE=0X00;
    70. delay_ms(50);
    71. PORTD=0b011110000;
    72. PORTE=0X00;
    73. delay_ms(50);
    74. PORTD=0b011100000;
    75. PORTE=0X00;
    76. delay_ms(50);
    77. PORTD=0b011000000;
    78. PORTE=0X00;
    79. delay_ms(50);
    80. PORTD=0b010000000;
    81. PORTE=0X00;
    82. delay_ms(50);
    83. PORTD=0b000000000;
    84. PORTE=0X00;
    85.
    86.
    87.
    88. delay_ms(50);
    89. PORTD=0b010000000;
    90. PORTE=0X00;
    91. delay_ms(50);
    92. PORTD=0b011000000;
    93. PORTE=0X00;
    94. delay_ms(50);
    95. PORTD=0b011100000;
    96. PORTE=0X00;
    97. delay_ms(50);
    98. PORTD=0b011110000;
    99. PORTE=0X00;
    100. delay_ms(50);
    101. PORTD=0b011111000;
    102. PORTE=0X00;
    103. delay_ms(50);
    104. PORTD=0b011110000;
    105. PORTE=0X00;
    106. delay_ms(50);
    107. PORTD=0b011100000;
    108. PORTE=0X00;
    109. delay_ms(50);
    110. PORTD=0b011000000;
    111. PORTE=0X00;
    112. delay_ms(50);
    113. PORTD=0b011100000;
    114. PORTE=0X00;
    115. delay_ms(50);
    116. PORTD=0b011110000;
    117. PORTE=0X00;
    118. delay_ms(50);
    119. PORTD=0b011111000;
    120. PORTE=0X00;
    121. delay_ms(50);
    122. PORTD=0b011111100;
    123. PORTE=0X00;
    124. delay_ms(50);
    125. PORTD=0b011111110;
    126. PORTE=0X00;
    127. delay_ms(50);
    128. PORTD=0b011111111;
    129. PORTE=0X00;
    130. delay_ms(50);
    131. PORTD=0b011111111;
    132. PORTE=0X00;
    133. delay_ms(50);
    134. PORTD=0b011111110;
    135. PORTE=0X00;
    136. delay_ms(50);
    137. PORTD=0b011111110;
    138. PORTE=0X00;
    139. delay_ms(50);
    140. PORTD=0b011111100;
    141. PORTE=0X00;
    142. delay_ms(50);
    143. PORTD=0b011111100;
    144. PORTE=0X00;
    145. delay_ms(50);
    146. PORTD=0b011111000;
    147. PORTE=0X00;
    148. delay_ms(50);
    149. PORTD=0b011111000;
    150. PORTE=0X00;
    151. delay_ms(50);
    152. PORTD=0b011110000;
    153. PORTE=0X00;
    154. delay_ms(50);
    155. PORTD=0b011110000;
    156. PORTE=0X00;
    157. delay_ms(50);
    158. PORTD=0b011100000;
    159. PORTE=0X00;
    160. delay_ms(50);
    161. PORTD=0b011100000;
    162. PORTE=0X00;
    163. delay_ms(50);
    164. PORTD=0b011000000;
    165. PORTE=0X00;
    166. delay_ms(50);
    167. PORTD=0b010000000;
    168. PORTE=0X00;
    169. delay_ms(50);
    170. PORTD=0b011100000;
    171. PORTE=0X00;
    172. delay_ms(50);
    173. PORTD=0b011111000;
    174. PORTE=0X00;
    175. delay_ms(50);
    176. PORTD=0b011111110;
    177. PORTE=0X00;
    178. delay_ms(50);
    179. PORTD=0b011111111;
    180. PORTE=0X00;
    181. delay_ms(50);
    182. PORTD=0b011111100;
    183. PORTE=0X00;
    184. delay_ms(50);
    185. PORTD=0b011111000;
    186. PORTE=0X00;
    187. delay_ms(50);
    188. PORTD=0b011100000;
    189. PORTE=0X00;
    190. delay_ms(50);
    191. PORTD=0b010000000;
    192. PORTE=0X00;
    193. delay_ms(50);
    194. PORTD=0b000000000;
    195. PORTE=0X00;
    196. delay_ms(50);
    197. PORTD=0b011000000;
    198. PORTE=0X00;
    199. delay_ms(50);
    200. PORTD=0b011111111;
    201. PORTE=0X00;
    202. delay_ms(50);
    203. PORTD=0b011111100;
    204. PORTE=0X00;
    205. delay_ms(50);
    206. PORTD=0b011111111;
    207. PORTE=0X00;
    208. delay_ms(50);
    209. PORTD=0b011111110;
    210. PORTE=0X00;
    211. delay_ms(50);
    212. PORTD=0b011111100;
    213. PORTE=0X00;
    214. delay_ms(50);
    215. PORTD=0b011111000;
    216. PORTE=0X00;
    217. delay_ms(50);
    218. PORTD=0b011110000;
    219. PORTE=0X00;
    220. delay_ms(50);
    221. PORTD=0b011100000;
    222. PORTE=0X00;
    223. delay_ms(50);
    224. PORTD=0b011000000;
    225. PORTE=0X00;
    226. delay_ms(50);
    227. PORTD=0b010000000;
    228. PORTE=0X00;
    229. delay_ms(50);}
    230. }
    231.
