PIC16f877a - Conversor A_D - LCD
Discussion in 'The Projects Forum' started by Enio Freitas, Oct 7, 2007.
  1. Enio Freitas
    Oct 7, 2007
    7
    Hello Guys,
    I'm doing a project with the 16f877a but I'm having problems with the proteus simulation. I tooke a model project with 1 analogic port and I want to change for 4 analogic ports, but this model project is'nt running in proteus correctly.
    I'm having a problem with the proteusVsLCD.
    do you use the LM016L LCD without problems? Is The frequency for it 250kHz?
  2. lightingman
    Apr 19, 2007
    374
    22
    You will have to configure the "adcon" registers to select the number of input that you wish to be analog inputs (check this on the data sheets).Your LCD should work fine.Daniel
  3. Enio Freitas
    Oct 7, 2007
    7
    Thanks, guy.
    I'll try it.
    After, i'll put the result of this new try.
  4. Enio Freitas
    Oct 7, 2007
    7
    Lightingman,
    My register Adcon0 and Adcon 1 are configured. I suspectthat the problem is in the proteus, but it is a model project that, I can't to do it in proteus.
    The LCD works but is'nt updating data.
    Thanks for your attention.
