PIC16F877A and Serial Port code
Discussion in 'Embedded Systems and Microcontrollers' started by betoelbarato, Dec 4, 2007.
  1. betoelbarato
    Nov 29, 2007
    hello I have a questoin about this code if someone can help me..
    this is the code I have for my pic
    #include <system.h>
    #define PIC16F877A
    #pragma CLOCK_FREQ 4000000
    char data1;
    void main ()
    trisd=00000000b; //set port d as output
    trisc=10000000b; //set port rc7 as input since the receiver
    //rx is there
    portc=0; //set port c to 0
    portd=0; //same for d
    intcon=11000000; //because I am using interrupts
    sprg=27; //I am using a boud rate in computer and
    //high speed formula in pic data sheet
    //9600=4000000(16(x+1)), x=27.04 so i put 27
    while (1) //loop so that the microcontroller keeps checking
    { //the signal that comes from the computer
    portd=0; / /portd = 0 so that if the data1 is not 1100001 then the
    //port d will not be on
    txsta=00100100b; // to enable enterrupts and to use baoud rate
    //high speed
    rcsta=10010000b; //to enable the serial port asynchronous receiver
    pie1=00100000b; // for using interrupts
    //the rcif flag
    // is set when reception is complete
    data1=rcreg; //read rcreg where the signal bits are stored
    if (data1==1100001) //or if the ascii of letter 'a' is received
    { //then the rd7 = high
    portd=10000000;
    and the plan that i have is to send a signal whith the computer using hyper terminal
    so lets say i send the letter a and while a keep pressing it the computer is going to send the signals to the pic and while the pic is recieving the letter a portd 7 is going to be high or an led concected to it will be on and if i stop pressing the letter a the port d is not going to be high and the led will be off
    so please tell me what i need to fix in my code because i know there are things wrrong maybe the while loop is not located correctly or a i do not know , I read the pic data sheet and i tryed to follow the steps to program the usart as it said but i do not know if its right
    thank you i'll appreciate your help
  2. eeboy
    Sep 27, 2007
    90
    A few things:
    1) You don't need to continuously enable RCV interrupts. Enable it once prior to entering the while loop.
    2) You will never see the LED light even if your code is written correctly. You have PORTD=0; at the beginning of the loop. You should change the if statement to an if/else similar...
    if(data1==1100001b){portd=1000000b;}else{portd=0;}
    3) Only read the RCREG when the int is set (RCIF).
  3. eeboy
    Sep 27, 2007
    90
    Got a little distracted while I was replying... regarding item 2....
    My solution still isn't what you are probably looking for. The LED pulse might be so short that you can't see it. Depending on your clock frequency. This while loop is going to be executing on the order of microseconds. So, when a byte is received it will set the PORTD pin but on the very next cycle of the loop the PORTD pin will be cleared until the next byte is received. Compare the cycle time of the loop to the baud rate and you will see how often this "blip" will occur.
    Make sense?
