PIC16f877 internal E2PROM....
Discussion in 'Embedded Systems and Microcontrollers' started by RRITESH KAKKAR, Jan 24, 2013.
  1. RRITESH KAKKAR
    Thread Starter Senior Member
    Jun 29, 2010
    2,831
    89
    I am working on LED matrix display for this i want to save the font in memory by header file....
    the problem is memory full of PIc so, i want to use empty memory space of E2PROM but i have no idea how to use it, in HI-TECH C® for PIC10/12/16
    User’s Guide the command was written but when i watch E2PROM window in MPlab 8.77 it shows all 0xFF, why??
    pls help me..
    Code ( (Unknown Language)):
    1.  eeprom_write(0x10, 0x1f);
  2. tshuck
    Oct 18, 2012
    3,531
    675
  3. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    I have solved this problem but i notice my code at reading E2PROM goes slow due to which the LED filkers...so, now i am not using E2PROM working on FLASH/program memory of 2000H...
    this syntax don't seems to work but when write any function with @ addr it the code save from that starting addr in memory.
    1. FLASH_WRITE(address,value);
