pic16f84 program problem
Discussion in 'Embedded Systems and Microcontrollers' started by ht systems, Nov 9, 2011.
  1. ht systems
    Aug 2, 2011
    71
    hello , i learned c++ language and i wrote a very simple program :
    void main()
    loop:
    TRISA=0B00000000;
    PORTA=0B00000001;
    goto loop;
    then i transform it to my programer and transform it into hex code but when i tried it , the chip didnt work as it should be
    the chip is : pic16f84
    4 M hz
    i am sure that my circuit is write
    i tried other examples but the same problem
    i think that the problem is in the programmer
    my programmer is : top win
    thanks
  2. ht systems
    Aug 2, 2011
    71
    no answer ........ !!!!
  3. ErnieM
    Apr 24, 2011
    7,443
    1,628
    You waited a whole 25 minutes to post again?
    WOW
    Can this programmer do a code verification to see what you wrote actually got there?
  4. ht systems
    Aug 2, 2011
    71
    yes it does , and the program is in the microchip .
  5. t06afre
    May 11, 2009
    5,939
    1,222
    In PICs it is something named configuration word(s). This should be described in the "SPECIAL FEATURES OF THE CPU" section of the data sheet. Have you given these settings any thought
  6. Eric007
    Aug 5, 2011
    1,056
    33
    t06afre made a good point I sometimes used to forget about the 'Config' thing...
    Without it nothing gets done!
  7. ht systems
    Aug 2, 2011
    71
    ok , thank you and i will recheck about the 'config' even i did it
  8. spinnaker
    Oct 29, 2009
    5,115
    1,195
    Buy a PICKit 2 or PICKit 3. You will be able to debug and even look at the hex code to make sure it actually go to the PIC.
    It is bad practice to use gotos in programming.
    Your code would be better written like this:
    Code ( (Unknown Language)):
    1.
    2.
    3. void main()
    4. {
    5.    while(1)
    6.    {
    7.        TRISA=0B00000000;
    8.        PORTA=0B00000001;
    9.    }
    10.
    11. }
    12.
    or better like this:
    1.
    2. void main()
    3.  {
    4.
    5.     TRISA=0B00000000;
    6.     PORTA=0B00000001;
    7.     while(1);
    8.
    9.  }
    10.
    This is assuming you do not want to do anything else in the loop.
    There is certainly no reason to put the setting of TRISA in a loop.
    Also check your datasheet and see if the PORTA pin has a corresponding analog input. If it does you may need to set it's ANS bit to 0 to get the pin to function as a binary pin.
  9. ht systems
    Aug 2, 2011
    71
    ok , i will try that , thank you
  10. ht systems
    Aug 2, 2011
    71
    is there any website that gives the steps for programming pic16fxx , it would really help , thank you
  11. nerdegutta
    Dec 15, 2009
    2,572
    807
  12. spinnaker
    Oct 29, 2009
    5,115
    1,195
    And if you buy the Microchip demo board mentioned in the ad, it should come with a tutorial.
    You might be able to download the tutorial without buying the board but you might need to make a few adjustments to the code.
    But if you are going to buy something then I would suggest the 18f45k22 demo board. It comes with a great tutorial. You might find the 18F a bit easier to work with if you are programming in C.
  13. ht systems
    Aug 2, 2011
    71
    im not sure if i can find it in the market and i cant buy it from the net so i will see anyway thank you so much for your help .
