PIC16F690 Potentiometers Shorting Out
Discussion in 'Embedded Systems and Microcontrollers' started by JDR04, May 23, 2014.
  1. JDR04
    Thread Starter Active Member
    May 5, 2011
    339
    Hope somebody is kind enough to point out what I have done wrong here.
    All this circuit does is flash an LED when the switch to PIN12 is pressed.
    VR1 sets a delay time before the LED is allowed to come on.
    VR2 sets how long the LED is allowed to stay on.
    VR3 sets a time out period that prevents the LED from being set on again.
    My problem is when I connect the pots up as in circuit A, they short/burn out when turned to the minimum.
    I am wondering if I need to place a resistor from the 6V line to each pot as I have done in circuit B? Would this be correct or is there a better solution?
    Thanks for the help....... JDR04
  2. MrChips
    Oct 2, 2009
    12,657
    3,461
    Perhaps the problem is caused by your program.
    Make certain that the pins used to connect to the pots are set for inputs.
    JDR04 likes this.
  3. olvine
    Member
    Mar 10, 2014
    99
    Why the supply voltage is 6V? Feed this 6V to a 5V voltage regulator....
    and yes there is a chance that your code is not right.
  4. John P
    Oct 14, 2008
    1,639
    225
    I think most likely you've wired the pots using the wrong terminals, so that as far as the power supply is concerned, they look like a variable resistor rather than a constant one--and at its lowest, that variable resistor is zero ohms.
    Also, don't put the feed to the potentiometers on the anode side of D1. That means that at the highest setting, the voltage sent to the A/D inputs would be higher than the processor's power supply, which means you can't measure it and it might cause problems with the input protection diodes. And, there should be a filter capacitor between pins 1 and 20 of the processor.
  5. t06afre
    May 11, 2009
    5,939
    1,222
    It is due to ESD protection diodes to VDD and VSS. See section 8.7 Analog Input Connection Considerations in the data sheet
    http://ww1.microchip.com/downloads/en/DeviceDoc/41262E.pdf
    As a rule of thumb for PICs. Never ever let any input voltage go higher than the supply voltage. Simple fix feed the pots from pin 1 of the PIC. You should also put a 100nF(about) close to pin 1 and down to ground
    JDR04 likes this.
  6. JDR04
    May 5, 2011
    339
    Hi olvine, I thought if I use 6V but then use a diode I'd lose about 0.7V and that will bring the supply voltage to within the PIC's specification.
    What do you think?
  7. JDR04
    May 5, 2011
    339
    Thanks John P. I'll give that a try.
  8. John P
    Oct 14, 2008
    1,639
    225
    The chip's specs allow you to go to 5.5V (absolute max is 6.5) so the diode should work, if you really must run from a 6V supply. It isn't the best way to do things though.
  9. JDR04
    May 5, 2011
    339
    Thanks John P. I'll give it a bash and see if I am cursed by a small wisp of white smoke............
  10. enggricha
    Member
    May 17, 2014
    62
    Do update what the problem and the solution you arrived at...i am curious about this problem. If this was something to do with the PICs i would like to learn from ur experience.
  11. JDR04
    May 5, 2011
    339
    Hi folks, managed to sort the problem out by using a 10K resistor between the wiper and the microcontroller pin. Have run for over 24hrs now and pots are still cool, no evil wisps of white rising up from my bench and setting the smoke detector off!!!
  12. THE_RB
    Feb 11, 2008
    5,435
    1,305
    That is what we call a "bandaid" solution.
    Your design is still bleeding to death, but now you put a bandaid on its wound so you don't see the blood. ;)
    At least the actual fault seems to be a lot clearer now? :)
  13. t06afre
    May 11, 2009
    5,939
    1,222
    That solution is kind of ouch!(shuddering)
    I suggest you do something like this, like I told to do. I also noticed a flaw in your switch design. Then the switch is not active it will be floating. That is a no-no in digital design.
    Edit the 10uF cap is kind of optional depending on how close it is to the 100uF cap
