1. reema paul
    Jun 28, 2010
    12
    hello all,
    i was having doubt in generation of 50hz pulse using pic16f676.
    it will be nice if i can get the code.
    also even after configuring pin 3(RA4) as o/p port..its giving me an o/p of 2.5 volts..i.e jumping between 5 and 0 v.how can i make it either low or high?is it associated with any other function?
    expecting a quick reply!
    thanks
  2. t06afre
    May 11, 2009
    5,939
    1,222
    To have a look at your code would be helpful
  3. reema paul
    Jun 28, 2010
    12
    #include "htc.h"
    unsigned char Dutycnt=0;
    unsigned int SV,BV,CT,SV0=0,BV0=0,CT0=0,x=0;
    void init_timer(void)
    TMR1H=0X0b;
    TMR1L=0Xdc;
    T1CON=0X00;
    T1CKPS1=1;
    T1CKPS0=1;
    TMR1IE=1;
    PEIE=1;
    GIE=1;
    void interrupt timer_isr(void)
    TMR1ON=0;
    if(RC4==1)
    x++;
    if(x==2)
    x=0;
    RC4=!RC4;
    if(RC3==1)
    x++;
    if(x==2)
    x=0;
    RC3=!RC3;
    TMR1IF=0;
    TMR1H=0X0B;
    TMR1L=0XDC;
    TMR1ON=1;
    void init_a2d(void)
    ADCON0=0x81;
    ADCON1=0x00;
    ANSEL=0X07;
    unsigned int read_a2d(void)
    unsigned int adc;
    ADCON0=0x83;
    while(ADCON0==0x83);
    adc=ADRESL+(ADRESH*256);
    return(adc);
    void main(void)
    unsigned int i;
    ANSEL=0X07;
    CMCON=7 ;
    TRISA=0X07;
    TRISC=0X00;
    PORTC=0X00;
    PORTA=0X00;
    init_a2d();
    init_timer();
    while(1)
    CHS0=1;
    CHS1=0;
    CHS2=0;
    BV=read_a2d();
    if(BV>=615)//greater than equal to 14v
    /*RC1=0;
    RC2=1;
    RC4=0;
    RA4=0;
    RC4=0;
    RA5=0;
    RC3=1;
    TMR1ON=0;
    if(BV<=448)//less than 10v
    //RC2=0;
    //RC1=1;
    //RC4=0;
    RA4=0;
    RC3=0;
    RC2=1;
    TMR1ON=0;
    if(BV>448&&BV<=483)//buzzer between 10v n 10.75v
    //RC2=0;
    //RC1=0;
    RA4=0;
    RC4=1; //BUZZER
    TMR1ON=1;
    else
    RC4=0;
    RA4=0;
    TMR1ON=0;
    //if(BV>702)
    //BV=702;
    BV0=BV;
    ********************EOP************************
    THOU HAVE MADE RA4 ZERO THROUGHOUT,STILL O/P REMAINS AT 2.5V N OSCILLOSCOPE GIVING SQUARE PULSES!
