PIC16F628A + DS18B20 + 7 segment [MikroC]
Discussion in 'Programmer's Corner' started by ducu, Aug 20, 2010.
  1. ducu
    Aug 18, 2010
    Hello people,
    After I set up the LCD temperature display, I want to show temperature on the digits (7 segments) in this method (00,0C) with 0,1 degree Celsius rezolution . I am using the MCU P16F628A, temperature sensor DS18B20 and 4 digit (7 segment) with common cathode.
    Language used is MikroC.
    Now, I have made some research and I create this code:
    Code ( (Unknown Language)):
    1.
    2. /*
    3. '*******************************************************************************
    4. ' Description:
    5.      The temperature most be displayed on the digits (7 segments) in this method (00,0C)
    6. ' Test configuration:
    7. '    MCU:                        PIC16F628A
    8. ' Configuration Word
    9. '    Oscillator:                 INTOSC:I/O on RA.6, I/O on RA.7
    10. '    Watchdog Timer:             OFF
    11. '    Power up Timer:             Disabled
    12. '    Master Clear Enable:        Enabled
    13. '    Browun Out Detect:          Enabled
    14. '    Low Voltage Program:        Disabled
    15. '    Data EE Read Protect:       Disabled
    16. '    Code Protect:               OFF
    17. '*******************************************************************************
    18. */
    19. //***********Declared mask*************/
    20. unsigned short mask(unsigned short num){
    21. switch (num) {
    22. case 0 : return 0x3F;
    23. case 1 : return 0x06;
    24. case 2 : return 0x5B;
    25. case 3 : return 0x4F;
    26. case 4 : return 0x66;
    27. case 5 : return 0x6D;
    28. case 6 : return 0x7D;
    29. case 7 : return 0x07;
    30. case 8 : return 0x7F;
    31. case 9 : return 0x6F;
    32. }
    33. }
    34. /*******Endless mask***********/
    35. unsigned short shifter, portb_index;
    36. unsigned short portb_array[4];
    37. unsigned char digit, J1, J2;
    38. unsigned int value;
    39. unsigned cc;
    40.
    41. void interrupt()
    42. {
    43. PORTA = 0;                           // Turn off all 7seg. displays;
    44. PORTB = portb_array[portb_index];    // Bring appropriate value to PORTB;
    45. PORTA = shifter;                     // Turn on appropriate 7seg. display;
    46.
    47. //move shifter to next digit;
    48. shifter <<= 1;
    49. if(shifter > 8u)
    50. shifter = 1;
    51.
    52. //increment portb_index;
    53. portb_index ++ ;
    54. if (portb_index > 3u)
    55. portb_index = 0;                     //turn on 1st, turn off 2nd 7 seg.;
    56. TMR0 = 0;                            //reset TIMER0 value;
    57. INTCON = 0x20;                       //clear T0IF, Bit T0IF=0, T0IE=1;
    58. }
    59. void sensor(){
    60.            INTCON.GIE = 0;             //Disable interrupt;
    61.            Ow_Reset (PORTA, 4);        //one wire reset signal;
    62.            Ow_Write (PORTA, 4, 0xCC);  //Issue command to DS18B20;
    63.            Ow_Write (PORTA, 4, 0X44);  //Issue command to DS18B20;
    64.            INTCON.GIE = 1;             //Enable interrupt;
    65.
    66.            Delay_ms(500);              //Wait for conversion complete;
    67.
    68.            INTCON.GIE = 0;
    69.            CC = Ow_Reset(PORTA ,4);
    70.            Ow_Write(PORTA, 4, 0XCC);   //Issue command to DS18B20;
    71.            Ow_Write(PORTA, 4, 0XBE);   //Issue command to DS18B20;
    72.            J1 = Ow_Read(PORTA ,4);     //Get result;
    73.            J2 = Ow_Read(PORTA ,4);     //Get result (assuming the temperature is positive);
    74.            INTCON.GIE = 1;             //Enable interrupt;
    75.
    76.            if(J2 = 0xFF)
    77.            J1 = J1 | 0XFF;             //Complement of two;
    78.            J1 = J1 + 1;
    79.
    80.            J2 = ((J1 & 0x01)* 5);      //Get decimal value;
    81.            J1 = J1 >> 1;               //From the 2byte variable;
    82.            value = ((J1*10) + J2);
    83. }
    84. void main()
    85. {
    86. CMCON |= 7;                          // Set AN pins to Digital I/O;
    87. OPTION_REG = 0x80;                   // Set timer TMR0;
    88. digit = 0;
    89. portb_index = 0;
    90. shifter = 1;
    91. TMR0 = 0;
    92. INTCON = 0xA0;                       // Disable interrupt PEIE,INTE,RBIE,T0IE
    93. PORTA = 0;                           // Turn off both displays
    94. TRISA = 0;                           // All port A pins are configured as outputs
    95. PORTB = 0;                           // Turn off all display segments
    96. TRISB = 0;                           // All port D pins are configured as outputs
    97.
    98. do {
    99.         sensor();
    100.
    101.            Delay_ms(500);
    102.
    103.            //Prepare digits for display;
    104.            digit = value % 10u;            //extract ones digit;
    105.            portb_array[0] = mask(digit);    //and store it to PORTB array;
    106.            digit = (value / 10u) % 10u;    //extract tens digit;
    107.            portb_array[1] = mask(digit);    //and store it to PORTB array;
    108.            digit = (value / 100u) % 10u;   //extract hundreds digit;
    109.            portb_array[2] = mask(digit);    //and store it to PORTB array;
    110.            digit = value / 1000u;          //extract thousands digit;
    111.            portb_array[3] = mask(digit);    //and store it to PORTB array;
    112.
    113.
    114.            }while(1);
    115. }
    116.
    Currently the 4 digits are displaying "0000" and it can be observed the multiplexing.
    Does anyone have any idea to fix this problem?
    Kind Regards,
    ducu
  2. tom66
    May 9, 2009
    2,613
    214
    What happens if you force the value to a specific value?
    Also, I'm not sure what J1 = J1 | 0xFF is supposed to do. It will effectively set all the bits in J1. You might as well do J1 = 0xFF. If you wanted to complement it, you need J1 = ~J1 or J1 = J1 ^ 0xFF (either works.)
  3. ducu
    Aug 18, 2010
    Hello tom66,
    The Symbol "|" represents an OR gate (specified in mikroc book).
    If i force to a specific value, that value is displayed on digits, but also have to do this line commented: //value = ((J1*10) + J2);
    I changed the line: J1 = J1 | 0xFF with this: J1 = J1 ^ 0xFF or J1 = ~J1, and the four digits varies between 0000 and 0260.
    I think the issue begin when transform in decimal value.
    Kind Regards,
    ducu
