Pic16F628a connection
Discussion in 'The Projects Forum' started by brian25, Jan 31, 2014.
  1. brian25
    May 13, 2013
    37
    i'm using this bluetooth shield, how's the connection between this and PIC16F628A stand alone microcontroller?
    can i connect directly the RX/TX of bt shield and PIC16F628A or do i need to put resistor between them?
    http://www.e-gizmo.com/KIT/BLUETOOTH%20SHIELD.html
    thanks
  2. tshuck
    Oct 18, 2012
    3,531
    675
    If you do it right, you don't need a resistor.
    That said, I always put 1.5k resistors between the TX to RX and RX to TX connections when prototyping, as I will sometimes swap pins when assembling the circuit.
    brian25 likes this.
