PIC16f628 radio link
Discussion in 'Embedded Systems and Microcontrollers' started by cykrus, Oct 1, 2012.
  1. cykrus
    Oct 1, 2012
    Hello all,
    I am very new to the micro-controller world so bare with me.
    I want to make a remote control to be able to send data between t PIC's (16f628). I know that there are already products out there (i have tested h12e/d rd600 d/e and they work great). My scope is to learn and play with PIC and not to use already made products :)
    Before this project i did the "flash led" type of tutorials to learn a little bit about PIC's. I have a picckit3 programmer and I'm using the PIC C compiler.
    Environment setup :
    I have 2 16f628 pic's and a set of 434 Mhz RX/TX. I also have a max 232
    connected to my serial port and receiver PIC in order to be able to debug data. At the hardware level have no problems setting it up.
    Software setup:
    The idea is that I want to be able to send a data package (comming from input pins) from PIC1(connected to the TX 434) to PIC2(connected to rx 434).
    An here comes the code I have already wrote. Again ... this is my first real program so bare with me :)
    DECODER
    Code ( (Unknown Language)):
    1.
    2. #include <16F628.h>
    3. #fuses INTRC_IO, NOLVP, NOWDT, PUT, BROWNOUT
    4. #use delay(clock=4000000)
    5. #use rs232(baud=19200, xmit=pin_B2, rcv=pin_B1)
    6.
    7.
    8. void display_binary(int c){
    9. int i;
    10.    i = 8;
    11.    do
    12.      {
    13.        if( c & 0x01 )
    14.          { putc('1'); }
    15.        else
    16.          { putc('0'); }
    17.
    18.        c >>= 1;  i--;
    19.      } while(i);
    20. }
    21.
    22.
    23. int sync(int a){
    24.    int found;
    25.    int string;
    26.    int bit;
    27.
    28.    int original;
    29.
    30.    original = a;
    31.
    32.    do{
    33.       a = original;
    34.       found = 0; // found the string
    35.       string = 0x00;
    36.
    37.       do{
    38.            if( input(PIN_A0) ){
    39.                bit = 0x01;
    40.            }
    41.            else{
    42.                bit = 0x00;
    43.            }
    44.            string = string | bit;
    45.            string <<= 1;
    46.
    47.            if( ((a & 0x01) ^ bit ) == 0 ){ // right bit == input
    48.                a >>= 1; // shift 1 position right
    49.            }
    50.            else{
    51.               return 0; // error
    52.            }
    53.
    54.            if( a == 0x00){
    55.                 found = 1;
    56.            }
    57.
    58.            delay_us(500); // wait until next bit
    59.
    60.       }while( found == 0 );
    61.
    62.   }while( found == 0 );
    63.
    64.   return 1;
    65. }
    66.
    67. int getdata(){
    68.
    69.    int string = 0x00;
    70.    int i;
    71.
    72.    for(i=0;i<8;i++){
    73.       string <<= 1;
    74.       if( input(PIN_A0) ){
    75.          string |= 0x01;
    76.       }
    77.       else{
    78.          string |= 0x00;
    79.       }
    80.       delay_us(500);
    81.    }
    82.
    83.    return string;
    84. }
    85.
    86.
    87. void main(void) {
    88.
    89.    int prev, k, i;
    90.    unsigned int data;
    91.
    92.    while(1) {
    93.
    94.       k=0; // until i get 3 time the same result
    95.       do{
    96.
    97.          i=0;
    98.          do{
    99.             if( sync(0xAB) == 1 ){
    100.                i++;
    101.                delay_us(500);
    102.             }
    103.             else{
    104.                i = 0;
    105.             }
    106.          }while(i<3);
    107.
    108.          data = getdata();
    109.
    110.          if( k > 0 && data != prev) k=1; // reset
    111.          else k++; // one more good result
    112.
    113.          prev = data; // previous result used in the next loop
    114.
    115.       }
    116.       while(k<3);
    117.
    118.       if( data == -1 ) output_high(PIN_A2);
    119.       if( data == 63 ) output_high(PIN_A1);
    120.
    121.       printf("Found %d = ", data);
    122.       display_binary(data);
    123.       printf("\r\n");
    124.
    125.       delay_ms(250);
    126.       output_low(PIN_A2);
    127.       output_low(PIN_A1);
    128.    }
    129.
    130. }
    131.
    ENCODER
    1.
    5.
    6. void send1(){
    7.    output_high(PIN_A0);
    8.    delay_us(500);
    9.    output_low(PIN_A0);
    10. }
    11. void send0(){
    12.    output_low(PIN_A0);
    13.    delay_us(500);
    14.    output_high(PIN_A0);
    15. }
    16.
    17. void sendbyte(int x){
    18.    int i=8;
    19.    do{
    20.       if(x & 0x01){
    21.          send1();
    22.       }
    23.       else{
    24.          send0();
    25.       }
    26.       x >>= 1;
    27.       i--;
    28.    }while(i);
    29. }
    30.
    31.
    32. main() {
    33.
    34.    while(true) {
    35.       if(input( PIN_B0) ){
    36.          // sync
    37.          sendbyte(0xAB);
    38.          delay_us(500);
    39.          sendbyte(0xAB);
    40.          delay_us(500);
    41.          sendbyte(0xAB);
    42.          delay_us(500);
    43.          sendbyte(0xFF);
    44.          delay_us(500);
    45.
    46.       }
    47.       else if(input( PIN_B1) ){
    48.          // sync
    49.          sendbyte(0xAB);
    50.          delay_us(500);
    51.          sendbyte(0xAB);
    52.          delay_us(500);
    53.          sendbyte(0xAB);
    54.          delay_us(500);
    55.          sendbyte(0xFC);
    56.          delay_us(500);
    57.      }
    58.    }
    59. }
    60.
    The idea is the encoder is sending 3 bytes (AB) as a sync (in order to align it with the RX) and then it send a byte of data depending on which pin B0 or B1 is high. The decoder searched for the 3 sync packages and then reads the byte (I'm reading it until i get 3 times the same value .. as i have experienced some errors due to radio noise i guess). Everything work so far but I'm sure it's not the perfect way to do it.
    My questions are :
    1. I have set a delay of 500us between bits and bytes as well. Is this correct ? What should be an optimal value ?
    2. I coded 2 function for sending 1 or 0 bits. Is there another way to send directly a full byte to a pic PIN ?
    2a. I have seen that in manchester it says that 1 is 0to1 transition and 1 is 1to0 ... does this mean that for sending a 1 I should do the following code ?
    1.
    2. output high;
    3. delay 250us;
    4. output_low;
    5. delay 250us
    6.
    How do i read this data (from port) on the other end ?
    3. I have studied for 1 week a lot about the manchester encoding, i have understood how it works but i dont know how to apply it to hardware. Meaning how to I put the bits on the PORTS and how do i read them ? What is the delay between bits ? I searched a whole week but did not find any c sample of this ... only the manchester encoding process.
    4. Is the way that i'm reading data from 434RX correct ? I have setup on both tx and rx same timing (delays between bits) and this is the way i "sync" .. is there another way do to this ?
    Please feel free to correct/adjust my code and tell me what do I do wrong.
    I want to learn and experimenting is for me the best way to do this.
    Thanks,
    Vlad
  2. cykrus
    Oct 1, 2012
    Another question just came into my mind. The way that i'm syncronising the encoder/decoder is my seting the same delay between bits. Now my question is this ... how much time does it take to execute operations between sending bits ? For example is the encoder has a code like
    1.
    2. output high
    3. delay 10us
    4. output low
    5. delay 10us
    6.
    and the decoder has the code
    1.
    2. read input
    3. delay 10us
    4. <=== other 10 instructions come here
    5. read input
    6. delay 10us
    7.
    How much does it take for the "10 instructions" to execute ... can that cause a delay and with the 10us added on top the second "input" would no longer be aligned with the encoder's timing ?
    How to solve this issue ... I suppose there is a way with the clock ? ... like in the so if we say "we'll meet there in 10 minutes" ... it is not so accurate as saying "we'll meet there at 2:50 PM" .. right ?
  3. cykrus
    Oct 1, 2012
    OOps ... i did some more reading and it looks like my code reinvented the wheel :)))) ... sorry for that ... i just discovered ... "USART" ...
    It looks like my code for sending/receiving bits is a "stoneage" version of USART ...
  4. cykrus
    Oct 1, 2012
    So .. after another day spent on forums i got the idea. I am using the UART and I have learner about all the registeres and bits for the rx buffer, error, etc etc. Great stuff ...
    So I managed to implement a fully working link with a 4 bit address and 8 bit (can be extended to 10 - two pins are still left as rx/tx for the wireless link ) data between 2 pic16f628.
    Next question just for fun ... can i save one more pin ? Is there a way when init the UART to only assign a pin (the tx) and rx to leave it undefined OR assigning it to some kind of NULL ?
