PIC16F627 code issue, need some help
Discussion in 'Embedded Systems and Microcontrollers' started by David5093, Apr 23, 2009.
  1. David5093
    Apr 23, 2009
    19
    I am trying to write some code that will give me two different outputs
    depending on what sequence of buttons (inputs) are pressed but it doesn't
    seem to work, keeps going to the fail routine no mater what button I press.
    Can anyone provide some assistance as to where or what i'm doing wrong?
    Regards
    David
    ;* VELLEMAN High-Q KIT K8048/VM111 SAMPLE SOFTWARE *
    ;* Microchip PIC(tm) Programmer & experiment board *
    ;* DEMO2 program for testing K8048 with PIC16F627(A)! *
    ;* Generate 4 LED light effects, you can select these with SW1..4 *
    ;* (C) VELLEMAN Components,2003 All rights reserved *
    ;* Hardw. Rev: P8048'1 Softw. Rev: 1.21 *
    ;* OSC.......: XT 4MHz Max. POWER.....: 12V DC *
    W EQU H'0000'
    F EQU H'0001'
    ;----- Register Files------------------------------------------------------
    INDF EQU H'0000'
    TMR0 EQU H'0001'
    PCL EQU H'0002'
    STATUS EQU H'0003'
    FSR EQU H'0004'
    PORTA EQU H'0005'
    PORTB EQU H'0006'
    INTCON EQU H'000B'
    OPTION_REG EQU H'0081'
    TRISA EQU H'0085'
    TRISB EQU H'0086'
    CMCON EQU H'001F'
    ;----- STATUS Bits --------------------------------------------------------
    IRP EQU H'0007'
    RP1 EQU H'0006'
    RP0 EQU H'0005'
    NOT_TO EQU H'0004'
    NOT_PD EQU H'0003'
    Z EQU H'0002'
    DC EQU H'0001'
    C EQU H'0000'
    ; RAM Definition
    __MAXRAM H'01FF'
    __BADRAM H'07'-H'09', H'0D', H'13'-H'14', H'1B'-H'1E'
    __BADRAM H'87'-H'89', H'8D', H'8F'-H'91', H'93'-H'97', H'9E'
    __BADRAM H'105', H'107'-H'109', H'10C'-H'11F', H'150'-H'16F'
    __BADRAM H'185', H'187'-H'189', H'18C'-H'1EF'
    ; Configuration Bits
    _BODEN_ON EQU H'3FFF'
    _BODEN_OFF EQU H'3FBF'
    _CP_ALL EQU H'03FF'
    _CP_75 EQU H'17FF'
    _CP_50 EQU H'2BFF'
    _CP_OFF EQU H'3FFF'
    _DATA_CP_ON EQU H'3EFF'
    _DATA_CP_OFF EQU H'3FFF'
    _PWRTE_OFF EQU H'3FFF'
    _PWRTE_ON EQU H'3FF7'
    _WDT_ON EQU H'3FFF'
    _WDT_OFF EQU H'3FFB'
    _LVP_ON EQU H'3FFF'
    _LVP_OFF EQU H'3F7F'
    _MCLRE_ON EQU H'3FFF'
    _MCLRE_OFF EQU H'3FDF'
    _ER_OSC_CLKOUT EQU H'3FFF'
    _ER_OSC_NOCLKOUT EQU H'3FFE'
    _INTRC_OSC_CLKOUT EQU H'3FFD'
    _INTRC_OSC_NOCLKOUT EQU H'3FFC'
    _EXTCLK_OSC EQU H'3FEF'
    _LP_OSC EQU H'3FEC'
    _XT_OSC EQU H'3FED'
    _HS_OSC EQU H'3FEE'
    __CONFIG _BODEN_ON & _CP_OFF & _DATA_CP_OFF & _PWRTE_ON & _WDT_OFF & _LVP_OFF & _MCLRE_ON & _XT_OSC
    ; Variable Definition
    ;INPUTS
    SW1 EQU H'00' ;SW1 is triggering RA0
    SW2 EQU H'01' ;SW2 is triggering RA1
    SW3 EQU H'02' ;SW3 is triggering RA2
    SW4 EQU H'03' ;SW4 is triggering RA3
    TIMER1 EQU H'20' ;Used in delay routine
    TIMER2 EQU H'21' ; " " "
    PATERN EQU H'22' ;Pattern data for effect's
    ORG 0 ;Reset vector address
    GOTO RESET ;goto RESET routine when boot.
    ; * Example of a delay routine *
    DELAY_ROUTINE MOVLW D'255'
    MOVWF TIMER2
    DEL_LOOP1 MOVLW D'255'
    MOVWF TIMER1
    DEL_LOOP2 DECFSZ TIMER1,F
    GOTO DEL_LOOP2
    DECFSZ TIMER2,F
    GOTO DEL_LOOP1
    RETLW 0
    ; ** RESET : main boot routine **
    RESET MOVLW B'00000111' ;Disable Comparator module's
    MOVWF CMCON
    BSF STATUS,RP0 ;Switch to register bank 1
    ;Disable pull-ups
    ;INT on rising edge
    ;TMR0 to CLKOUT
    ;TMR0 Incr low2high trans.
    ;Prescaler assign to Timer0
    ;Prescaler rate is 1:256
    MOVLW B'11010111' ;Set PIC options (See datasheet).
    MOVWF OPTION_REG ;Write the OPTION register.
    CLRF INTCON ;Disable interrupts
    MOVLW B'11000000'
    MOVWF TRISB ;RB7 & RB6 are inputs.
    ;RB5...RB0 are outputs.
    MOVLW B'11111111' ;all RA ports are inputs
    MOVWF TRISA
    BCF STATUS,RP0 ;Switch Back to reg. Bank 0
    CLRF PORTB
    GOTO MENU
    MENU CLRF PORTB
    BTFSC PORTA,SW1
    GOTO FAILURE
    BTFSC PORTA,SW2
    GOTO FAILURE
    BTFSC PORTA,SW3
    GOTO FAILURE
    BTFSC PORTA,SW4
    GOTO SEQ_1
    GOTO MENU
    SEQ_1 BTFSC PORTA,SW2 ; Wait for Switch 2 to release
    GOTO SEQ_2 ; If so wait for Switch 3
    BTFSC PORTA,SW1 ; If Switch 1 is pressed, Fail
    GOTO FAILURE
    BTFSC PORTA,SW3 ; If Switch 3 is pressed, Fail
    GOTO FAILURE
    BTFSC PORTA,SW4 ; If Switch 4 is pressed, Fail
    GOTO FAILURE
    SEQ_2 BTFSC PORTA,SW3 ; Wait for switch 3 to release
    GOTO SEQ_3 ; If so wait for Switch 1
    GOTO FAILURE
    BTFSC PORTA,SW2 ; If Switch 2 is pressed, Fail
    GOTO FAILURE
    GOTO FAILURE
    SEQ_3 BTFSC PORTA,SW1 ; Wait for Switch 1 to release
    GOTO PASS ; If so you have Passed
    GOTO FAILURE
    GOTO FAILURE
    GOTO FAILURE
    PASS MOVLW B'00100000' ;
    MOVWF PORTB
    CALL DELAY_ROUTINE
    MOVLW B'00110000' ;
    MOVWF PORTB
    CALL DELAY_ROUTINE
    MOVLW B'00111000' ;
    MOVWF PORTB
    CALL DELAY_ROUTINE
    MOVLW B'00111100' ;
    MOVWF PORTB
    CALL DELAY_ROUTINE
    MOVLW B'00111110' ;
    MOVWF PORTB
    CALL DELAY_ROUTINE
    MOVLW B'00111111' ;
    MOVWF PORTB
    CALL DELAY_ROUTINE
    MOVLW B'00111110' ;
    MOVWF PORTB
    CALL DELAY_ROUTINE
    MOVLW B'00111100' ;
    MOVWF PORTB
    CALL DELAY_ROUTINE
    MOVLW B'00111000' ;
    MOVWF PORTB
    CALL DELAY_ROUTINE
    MOVLW B'00110000' ;
    MOVWF PORTB
    CALL DELAY_ROUTINE
    GOTO PASS
    FAILURE MOVLW 0x3F ; Moves (63 decimal, 111111 binary) into the W register
    MOVWF PORTA ; Set all bits on
    MOVWF PORTB ; LEDs on
    NOP ; The 'nop' make up the time taken by the goto
    NOP ; giving a square wave output
    CALL DELAY_ROUTINE
    CALL DELAY_ROUTINE
    CALL DELAY_ROUTINE
    CALL DELAY_ROUTINE
    CALL DELAY_ROUTINE
    MOVLW 0x00 ; Moves (00 decimal, 000000 binary) into the W register
    MOVWF PORTA ; Set all bits off
    MOVWF PORTB ; LEDs off
    CALL DELAY_ROUTINE
    CALL DELAY_ROUTINE
    CALL DELAY_ROUTINE
    CALL DELAY_ROUTINE
    CALL DELAY_ROUTINE
    GOTO FAILURE ; Repeat
    END
  2. David5093
    Apr 23, 2009
    19
    Can someone even point me in the right direction?
  3. Celliers
    Jan 3, 2009
    Who wrote the code? is it a sample u modified or your own?
  4. David5093
    Apr 23, 2009
    19
    Its a sample that I modified.
  5. n9352527
    Oct 14, 2005
    1,198
    The intended key sequence seems to be 4-2-3-1. The code only checks for switches being pressed, without checking for releases, despite the comments saying otherwise.
    So, when a right switch is pressed, the code moves to the next sequence and checks for the next switch press. However, because the micro is far faster than a human can release the switch, that first switch is not yet released. The code then thinks that a wrong switch is pressed and jumps to fail routine.
    To wait for a switch release, use this code:
    btfsc PORTA, SWx
    goto $ - 1 ; not released, check again
    ... ; released, do the next thing
  6. thatoneguy
    Feb 19, 2009
    6,357
    718
    Add debouncing, either in software or hardware. The uC is probably "Seeing" 4-4-4-3-3-2-2-2-1-1-1-1 when 4-3-2-1 are pressed.
    Debouncing can be "x of y" sampling, where a variable is incremented each time through the loop and the switch is active. Every 10 "loops", variable is checked, and if > 8, the switch is debounced, variable is set to zero, and 'switch pressed' routine is called.
    Don't use a long delay routine for debouncing, as they cause the processor to miss non-interrupt events, such as LCD updating, other keypresses, etc. This makes the end application "feel kludgy", even when the delays are 1mS (they add up).
    Whenever you need a delay, build it into the "main loop". This uses two variables and a couple lines of code in the main loop. One variable as a counter, another as a "flag", or however it's easier to think of. When time needs to be spent, set the "flag", the rest of the code runs, and unless the desired delay is reached, the flag isn't reset. At the start of the procedure needing the delay, test the flag, and continue if true. Similar to ADC procedures.
    The above is a bit difficult in assembly. The simplest would be a hardware RC network, 10k pullup and 0.1uF cap to ground, with the input where the R and C connect. This also gives the benefit of reducing interference if using wires rather than a PCB trace to connect the switches.
  7. David5093
    Apr 23, 2009
    19
    n9352527/Thatoneguy,
    Both of you thanks for your help, working away nicely, thanks again
  8. David5093
    Apr 23, 2009
    19
    orry guys,
    I spoke too soon when I said it was working.
    Yeah, the sequence I want is 4-2-3-1 = Pass routine, anything else = Fail routine.
    When I switch on and press buttons 1, 2 or 3 it goes to the fail routine which is what I want, however
    when I press button 2 it automatically goes to Pass (for some reason) when i want it to wait for the
    next input.
    Any ideas?
    The code below:
    ;INPUTS
    MOVWF TIMER2
    MOVWF TIMER1
    GOTO DEL_LOOP2
    DECFSZ TIMER2,F
    GOTO DEL_LOOP1
    RETLW 0
    MOVWF CMCON
    ;Disable pull-ups
    ;INT on rising edge
    ;TMR0 to CLKOUT
    MOVLW B'11000000'
    MOVWF TRISA
    CLRF PORTB
    GOTO MENU
    MENU CLRF PORTB
    BTFSC PORTA,SW1
    GOTO FAILURE
    BTFSC PORTA,SW2
    GOTO FAILURE
    BTFSC PORTA,SW3
    GOTO FAILURE
    BTFSC PORTA,SW4
    GOTO SEQ_1
    GOTO MENU
    GOTO $-1 ; Not released, check again
    GOTO FAILURE
    GOTO FAILURE
    GOTO FAILURE
    GOTO $-1 ; Not released, check agin
    GOTO FAILURE
    GOTO FAILURE
    GOTO FAILURE
    GOTO FAILURE
    GOTO FAILURE
    GOTO FAILURE
    MOVWF PORTB
    CALL DELAY_ROUTINE
    MOVLW B'00110000' ;
    MOVWF PORTB
    CALL DELAY_ROUTINE
    MOVLW B'00111000' ;
    MOVWF PORTB
    CALL DELAY_ROUTINE
    MOVLW B'00111100' ;
    MOVWF PORTB
    CALL DELAY_ROUTINE
    MOVLW B'00111110' ;
    MOVWF PORTB
    CALL DELAY_ROUTINE
    MOVLW B'00111111' ;
    MOVWF PORTB
    CALL DELAY_ROUTINE
    MOVLW B'00111110' ;
    MOVWF PORTB
    CALL DELAY_ROUTINE
    MOVLW B'00111100' ;
    MOVWF PORTB
    CALL DELAY_ROUTINE
    MOVLW B'00111000' ;
    MOVWF PORTB
    CALL DELAY_ROUTINE
    MOVLW B'00110000' ;
    MOVWF PORTB
    CALL DELAY_ROUTINE
    GOTO PASS
    CALL DELAY_ROUTINE
    CALL DELAY_ROUTINE
    CALL DELAY_ROUTINE
    CALL DELAY_ROUTINE
    CALL DELAY_ROUTINE
    CALL DELAY_ROUTINE
    CALL DELAY_ROUTINE
    CALL DELAY_ROUTINE
    CALL DELAY_ROUTINE
    CALL DELAY_ROUTINE
    END
  9. thatoneguy
    Feb 19, 2009
    6,357
    718
    This Part:
    Code ( (Unknown Language)):
    1.
    2. SEQ_1  BTFSC PORTA,SW2 ; Wait for Switch 2 to release
    3.   GOTO $-1  ; Not released, check again
    4.   GOTO SEQ_2  ; If so wait for Switch 3
    5.   BTFSC PORTA,SW1 ; If Switch 1 is pressed, Fail
    6.
    Executes right after the First checks.
    It should only run if a flag stating switch 2 has been pressed is set, otherwise it will trigger when it isn't pressed on every "loop".
  10. David5093
    Apr 23, 2009
    19
    Ok,thanks. Next question, how do I set a flag?
  11. David5093
    Apr 23, 2009
    19
    I tried another way but still it doesn't work, any idea why?
    W EQU H'0000'
    F EQU H'0001'
    INDF EQU H'0000'
    TMR0 EQU H'0001'
    PCL EQU H'0002'
    STATUS EQU H'0003'
    FSR EQU H'0004'
    PORTA EQU H'0005'
    PORTB EQU H'0006'
    INTCON EQU H'000B'
    TRISA EQU H'0085'
    TRISB EQU H'0086'
    CMCON EQU H'001F'
    IRP EQU H'0007'
    RP1 EQU H'0006'
    RP0 EQU H'0005'
    NOT_TO EQU H'0004'
    NOT_PD EQU H'0003'
    Z EQU H'0002'
    DC EQU H'0001'
    C EQU H'0000'
    ; RAM Definition
    __MAXRAM H'01FF'
    _CP_ALL EQU H'03FF'
    _CP_75 EQU H'17FF'
    _CP_50 EQU H'2BFF'
    _CP_OFF EQU H'3FFF'
    _WDT_ON EQU H'3FFF'
    _LVP_ON EQU H'3FFF'
    _LP_OSC EQU H'3FEC'
    _XT_OSC EQU H'3FED'
    _HS_OSC EQU H'3FEE'
    ;INPUTS
    MOVWF TIMER2
    MOVWF TIMER1
    GOTO DEL_LOOP2
    DECFSZ TIMER2,F
    GOTO DEL_LOOP1
    RETLW 0
    MOVWF CMCON
    ;Disable pull-ups
    ;INT on rising edge
    ;TMR0 to CLKOUT
    MOVLW B'11000000'
    MOVWF TRISA
    CLRF PORTB
    GOTO MENU
    MENU CLRF PORTB
    BTFSC PORTA,SW1
    GOTO FAILURE
    BTFSC PORTA,SW2
    GOTO FAILURE
    BTFSC PORTA,SW3
    GOTO FAILURE
    BTFSC PORTA,SW4
    GOTO RESET_1
    GOTO MENU
    RESET_1 MOVLW B'00000111' ;Disable Comparator module's
    MOVWF CMCON
    ;Disable pull-ups
    ;INT on rising edge
    ;TMR0 to CLKOUT
    MOVLW B'11000000'
    MOVWF TRISA
    CLRF PORTB
    GOTO MENU_1
    MENU_1 CLRF PORTB
    BTFSC PORTA,SW1
    GOTO FAILURE
    BTFSC PORTA,SW2
    GOTO RESET_2
    BTFSC PORTA,SW3
    GOTO FAILURE
    BTFSC PORTA,SW4
    GOTO FAILURE
    GOTO MENU_1
    RESET_2 MOVLW B'00000111' ;Disable Comparator module's
    MOVWF CMCON
    ;Disable pull-ups
    ;INT on rising edge
    ;TMR0 to CLKOUT
    MOVLW B'11000000'
    MOVWF TRISA
    CLRF PORTB
    GOTO MENU_2
    MENU_2 CLRF PORTB
    BTFSC PORTA,SW1
    GOTO FAILURE
    BTFSC PORTA,SW2
    GOTO FAILURE
    BTFSC PORTA,SW3
    GOTO RESET_3
    BTFSC PORTA,SW4
    GOTO FAILURE
    GOTO MENU_2
    RESET_3 MOVLW B'00000111' ;Disable Comparator module's
    MOVWF CMCON
    ;Disable pull-ups
    ;INT on rising edge
    ;TMR0 to CLKOUT
    MOVLW B'11000000'
    MOVWF TRISA
    CLRF PORTB
    GOTO MENU_3
    MENU_3 CLRF PORTB
    BTFSC PORTA,SW1
    GOTO PASS
    BTFSC PORTA,SW2
    GOTO FAILURE
    BTFSC PORTA,SW3
    GOTO FAILURE
    BTFSC PORTA,SW4
    GOTO FAILURE
    GOTO MENU_3
    MOVWF PORTB
    CALL DELAY_ROUTINE
    MOVLW B'00110000' ;
    MOVWF PORTB
    CALL DELAY_ROUTINE
    MOVLW B'00111000' ;
    MOVWF PORTB
    CALL DELAY_ROUTINE
    MOVLW B'00111100' ;
    MOVWF PORTB
    CALL DELAY_ROUTINE
    MOVLW B'00111110' ;
    MOVWF PORTB
    CALL DELAY_ROUTINE
    MOVLW B'00111111' ;
    MOVWF PORTB
    CALL DELAY_ROUTINE
    MOVLW B'00111110' ;
    MOVWF PORTB
    CALL DELAY_ROUTINE
    MOVLW B'00111100' ;
    MOVWF PORTB
    CALL DELAY_ROUTINE
    MOVLW B'00111000' ;
    MOVWF PORTB
    CALL DELAY_ROUTINE
    MOVLW B'00110000' ;
    MOVWF PORTB
    CALL DELAY_ROUTINE
    GOTO PASS
    CALL DELAY_ROUTINE
    CALL DELAY_ROUTINE
    CALL DELAY_ROUTINE
    CALL DELAY_ROUTINE
    CALL DELAY_ROUTINE
    CALL DELAY_ROUTINE
    CALL DELAY_ROUTINE
    CALL DELAY_ROUTINE
    CALL DELAY_ROUTINE
    CALL DELAY_ROUTINE
    END
  12. David5093
    Apr 23, 2009
    19
    Right, I had another go with this and still can't get it to work. Can someone offer some assistance, please?
  13. thatoneguy
    Feb 19, 2009
    6,357
    718
    Sorry for absence. A "Flag" is simply a variable to test.
    It can be a byte or a single bit, such as the STATUS register.
    If you are tracking the state of 4 buttons, 2 bits would work, but you have the memory to simply use a byte.
    If the variable is zero, it is waiting for the first keypress
    If the variable is 1, the initial key was pressed, waiting for debounce, on continue, increment variable.
    keys 2 and 3 do essentially the same as key 1
    The 4th key performs the "Correct keys" function if correct, and sets the variable back to zero.
    If any key is wrong, the variable is reset to zero as well.
  14. David5093
    Apr 23, 2009
    19
    Okay doke,
    Now how do I incorporate that into PIC code?
  15. gryskop
    Member
    Mar 1, 2008
    26
    1.
    2.
    3. ;************************************************* *************************
    4. ;* VELLEMAN High-Q KIT K8048/VM111 SAMPLE SOFTWARE *
    5. ;************************************************* *************************
    6. ;* Microchip PIC(tm) Programmer & experiment board *
    7. ;* DEMO2 program for testing K8048 with PIC16F627(A)! *
    8. ;* Generate 4 LED light effects, you can select these with SW1..4 *
    9. ;************************************************* *************************
    10. ;* (C) VELLEMAN Components,2003 All rights reserved *
    11. ;************************************************* *************************
    12. ;* Hardw. Rev: P8048'1 Softw. Rev: 1.21 *
    13. ;* OSC.......: XT 4MHz Max. POWER.....: 12V DC *
    14. ;************************************************* *************************
    15. ;
    16. ; -----> Making use of MPLAB IDE v8.x to run simulation
    17. [COLOR="Red"]   radix   dec
    18.     list p=16F627A
    19.     include "P16F627A.INC"
    20.     ERRORLEVEL      -302
    21.     ERRORLEVEL      -305
    22. [/COLOR]
    23.
    24.     __CONFIG _BODEN_ON & _CP_OFF & _DATA_CP_OFF & _PWRTE_ON & _WDT_OFF & _LVP_OFF & _MCLRE_ON & _XT_OSC
    25. ;================================================= =========================
    26. ; Variable Definition
    27. ;================================================= =========================
    28. ;INPUTS
    29. SW1     EQU H'00' ;SW1 is triggering RA0
    30. SW2     EQU H'01' ;SW2 is triggering RA1
    31. SW3     EQU H'02' ;SW3 is triggering RA2
    32. SW4     EQU H'03' ;SW4 is triggering RA3
    33. TIMER1      EQU H'20' ;Used in delay routine
    34. TIMER2      EQU H'21' ; " " "
    35. PATERN      EQU H'22' ;Pattern data for effect's
    36.
    37.         ORG 0       ;Reset vector address
    38.         GOTO    RESET       ;goto RESET routine when boot.
    39.
    40. ; *********************************************
    41. ; * Example of a delay routine *
    42. ; *********************************************
    43. DELAY_ROUTINE   MOVLW   D'255'
    44.         MOVWF   TIMER2
    45. DEL_LOOP1   MOVLW   D'255'
    46.         MOVWF   TIMER1
    47. DEL_LOOP2   DECFSZ  TIMER1,F
    48.         GOTO    DEL_LOOP2
    49.         DECFSZ  TIMER2,F
    50.         GOTO    DEL_LOOP1
    51.         RETLW   0
    52.
    53. ; **********************************
    54. ; ** RESET : main boot routine **
    55. ; **********************************
    56. RESET       MOVLW   B'00000111'     ;Disable Comparator module's
    57.         MOVWF   CMCON
    58.         BSF STATUS,RP0      ;Switch to register bank 1
    59. ;Disable pull-ups
    60. ;INT on rising edge
    61. ;TMR0 to CLKOUT
    62. ;TMR0 Incr low2high trans.
    63. ;Prescaler assign to Timer0
    64. ;Prescaler rate is 1:256
    65.         MOVLW   B'11010111'     ;Set PIC options (See datasheet).
    66.         MOVWF   OPTION_REG      ;Write the OPTION register.
    67.         CLRF    INTCON          ;Disable interrupts
    68.         MOVLW   B'11000000'
    69.         MOVWF   TRISB           ;RB7 & RB6 are inputs.
    70. ;RB5...RB0 are outputs.
    71.         MOVLW   B'11111111'     ;all RA ports are inputs
    72.         MOVWF   TRISA
    73.         BCF STATUS,RP0      ;Switch Back to reg. Bank 0
    74.         CLRF    PORTB
    75.         GOTO    MENU
    76. ;
    77. MENU        CLRF    PORTB
    78.                         ; ----------------------->
    79.         BTFSC   PORTA,SW1       [COLOR="Red"]; No allowance made for button debounce timer[/COLOR]
    80.         GOTO    FAILURE         [COLOR="Red"]; Simulating an input will work, but in real [/COLOR]
    81.         BTFSC   PORTA,SW2       [COLOR="Red"]; life you will battle to pick up if a switch[/COLOR]
    82.         GOTO    FAILURE         [COLOR="Red"]; was pressed[/COLOR]
    83.         BTFSC   PORTA,SW3       ;
    84.         GOTO    FAILURE         ;
    85.         BTFSC   PORTA,SW4       ;
    86.         GOTO    RESET_1         ;
    87.         GOTO    MENU
    88. RESET_1     MOVLW   B'00000111'         ;Disable Comparator module's
    89.         MOVWF   CMCON
    90. ;
    91.         BSF STATUS,RP0      ;Switch to register bank 1
    92. ;Disable pull-ups
    93. ;INT on rising edge
    94. ;TMR0 to CLKOUT
    95. ;TMR0 Incr low2high trans.
    96. ;Prescaler assign to Timer0
    97. ;Prescaler rate is 1:256
    98.         MOVLW   B'11010111'         ;Set PIC options (See datasheet).
    99.         MOVWF   OPTION_REG      ;Write the OPTION register.
    100.         CLRF    INTCON          ;Disable interrupts
    101.         MOVLW   B'11000000'
    102.         MOVWF   TRISB           ;RB7 & RB6 are inputs.
    103.                         ;RB5...RB0 are outputs.
    104.         MOVLW   B'11111111'         ;all RA ports are inputs
    105.         MOVWF   TRISA
    106.         BCF STATUS,RP0      ;Switch Back to reg. Bank 0
    107.         CLRF    PORTB
    108.         GOTO    MENU_1
    109. ;
    110. MENU_1      CLRF    PORTB
    111. ;
    112.         BTFSC   PORTA,SW1
    113.         GOTO    FAILURE
    114.         BTFSC   PORTA,SW2
    115.         GOTO    RESET_2
    116.         BTFSC   PORTA,SW3
    117.         GOTO    FAILURE
    118.         BTFSC   PORTA,SW4
    119.         GOTO    FAILURE
    120.         GOTO    MENU_1
    121. RESET_2     MOVLW   B'00000111'         ;Disable Comparator module's
    122.         MOVWF   CMCON
    123.                         ;
    124.         BSF STATUS,RP0      ;Switch to register bank 1
    125.                         ;Disable pull-ups
    126.                         ;INT on rising edge
    127.                         ;TMR0 to CLKOUT
    128.                         ;TMR0 Incr low2high trans.
    129.                         ;Prescaler assign to Timer0
    130.                         ;Prescaler rate is 1:256
    131.         MOVLW   B'11010111'         ;Set PIC options (See datasheet).
    132.         MOVWF   OPTION_REG      ;Write the OPTION register.
    133.                         ;
    134.         CLRF    INTCON          ;Disable interrupts
    135.         MOVLW   B'11000000'
    136.         MOVWF   TRISB           ;RB7 & RB6 are inputs.
    137.                         ;RB5...RB0 are outputs.
    138.         MOVLW   B'11111111'         ;all RA ports are inputs
    139.         MOVWF   TRISA
    140.         BCF STATUS,RP0      ;Switch Back to reg. Bank 0
    141.         CLRF    PORTB
    142.         GOTO    MENU_2
    143.                         ;
    144. MENU_2      CLRF    PORTB
    145.                         ;
    146.         BTFSC   PORTA,SW1
    147.         GOTO    FAILURE
    148.         BTFSC   PORTA,SW2
    149.         GOTO    FAILURE
    150.         BTFSC   PORTA,SW3
    151.         GOTO    RESET_3
    152.         BTFSC   PORTA,SW4
    153.         GOTO    FAILURE
    154.         GOTO    MENU_2
    155.
    156. RESET_3     MOVLW   B'00000111'         ;Disable Comparator module's
    157.         MOVWF   CMCON
    158.                         ;
    159.         BSF STATUS,RP0      ;Switch to register bank 1
    160.                         ;Disable pull-ups
    161.                         ;INT on rising edge
    162.                         ;TMR0 to CLKOUT
    163.                         ;TMR0 Incr low2high trans.
    164.                         ;Prescaler assign to Timer0
    165.                         ;Prescaler rate is 1:256
    166.         MOVLW   B'11010111'         ;Set PIC options (See datasheet).
    167.         MOVWF   OPTION_REG      ;Write the OPTION register.
    168.                         ;
    169.         CLRF    INTCON          ;Disable interrupts
    170.         MOVLW   B'11000000'
    171.         MOVWF   TRISB           ;RB7 & RB6 are inputs.
    172.                         ;RB5...RB0 are outputs.
    173.         MOVLW   B'11111111'         ;all RA ports are inputs
    174.         MOVWF   TRISA
    175.         BCF STATUS,RP0      ;Switch Back to reg. Bank 0
    176.         CLRF    PORTB
    177.         GOTO    MENU_3
    178.                         ;
    179. MENU_3      CLRF    PORTB
    180.                         ;
    181.         BTFSC   PORTA,SW1
    182.         GOTO    PASS
    183.         BTFSC   PORTA,SW2
    184.         GOTO    FAILURE
    185.         BTFSC   PORTA,SW3
    186.         GOTO    FAILURE
    187.         BTFSC   PORTA,SW4
    188.         GOTO    FAILURE
    189.         GOTO    MENU_3
    190.
    191. PASS        MOVLW   B'00100000'         ;
    192.         MOVWF   PORTB
    193.         CALL    DELAY_ROUTINE
    194.         MOVLW   B'00110000'         ;
    195.         MOVWF   PORTB
    196.         CALL    DELAY_ROUTINE
    197.         MOVLW   B'00111000'         ;
    198.         MOVWF   PORTB
    199.         CALL    DELAY_ROUTINE
    200.         MOVLW   B'00111100'         ;
    201.         MOVWF   PORTB
    202.         CALL    DELAY_ROUTINE
    203.         MOVLW   B'00111110'         ;
    204.         MOVWF   PORTB
    205.         CALL    DELAY_ROUTINE
    206.         MOVLW   B'00111111'         ;
    207.         MOVWF   PORTB
    208.         CALL    DELAY_ROUTINE
    209.         MOVLW   B'00111110'         ;
    210.         MOVWF   PORTB
    211.         CALL    DELAY_ROUTINE
    212.         MOVLW   B'00111100'         ;
    213.         MOVWF   PORTB
    214.         CALL    DELAY_ROUTINE
    215.         MOVLW   B'00111000'         ;
    216.         MOVWF   PORTB
    217.         CALL    DELAY_ROUTINE
    218.         MOVLW   B'00110000'         ;
    219.         MOVWF   PORTB
    220.         CALL    DELAY_ROUTINE
    221.         GOTO    PASS
    222.
    223. FAILURE     MOVLW   0x3F            ; Moves (63 decimal, 111111 binary) into the W register
    224.         MOVWF   PORTA           ; Set all bits on
    225.         MOVWF   PORTB           ; LEDs on
    226.         NOP                 ; The 'nop' make up the time taken by the goto
    227.         NOP                 ; giving a square wave output
    228.         CALL    DELAY_ROUTINE
    229.         CALL    DELAY_ROUTINE
    230.         CALL    DELAY_ROUTINE
    231.         CALL    DELAY_ROUTINE
    232.         CALL    DELAY_ROUTINE
    233.         MOVLW   0x00            ; Moves (00 decimal, 000000 binary) into the W register
    234.         MOVWF   PORTA           ; Set all bits off
    235.         MOVWF   PORTB           ; LEDs off
    236.         CALL    DELAY_ROUTINE
    237.         CALL    DELAY_ROUTINE
    238.         CALL    DELAY_ROUTINE
    239.         CALL    DELAY_ROUTINE
    240.         CALL    DELAY_ROUTINE
    241.         GOTO    FAILURE         ; Repeat
    242.         END
    243.
    244.
    What software package are you using for programming?
    If you use MPLAB IDE, you can get rid of register, bit, ram and configuration declarations in the beginning of the code. Simply add the line
    I don’t see any debounce routines for the switches. Read up some more on debounce, but a typical button debounce time is between 5ms to 20ms. When using software simulators the code will work, but in an actual real life application you might have trouble.
    Why do you keep on repeating the port setup with all the RESET routines? Unless the ports change function (i.e. from input to output) during the run of the software you only need to set it once. Usually that should happen in the beginning, i.e. it should be the first routine to be called and then never again, until the next reset or power failure.
    The way your code is written is that will forever loop in any of the MENU_x routines and once a button is pressed it will go to FAILURE and then it will stay there forever. Was this your intention?
  16. David5093
    Apr 23, 2009
    19
    No, my intention is for the program to goto the pass routine when the sequence 4-2-3-1 is pressed, any deviation from this then it goes to the fail routine.
    The reason i repeated the reset function was because the program is waiting for an input when i first run it so by pressing 4 i thought it would wait again for another input before reacting and so on but it doesn't work.
    Is debounce routine the way to go?
  17. David5093
    Apr 23, 2009
    19
    Any pointers on how to implement a debounce routine?
  18. gryskop
    Member
    Mar 1, 2008
    26
    Have a look at page 94 of this document
  19. David5093
    Apr 23, 2009
    19
    Been reading up on de-bouncing and tried to incorporate it into the program. My programming knowledge consits of cut and paste of different routines so not really sure what i'm doing. What I want is for the program to wait for a sequence of inputs from buttons (4,2,3,1) which if pressed will goto the Pass routine, any deviation from this then the program will run the Failure routine. This seems fairly straight forward to me but cannot seem to get it to work correctly. Can someone have a look at my latest try and see if there are any glaring errors as I have no idea.
    I have attached the program as a text document as the formatting is messed up when i paste it
    Regards
    David
  20. David5093
    Apr 23, 2009
    19
    Anyone any ideas?
