PIC16F1938 SD WAV Player
GOkussj5okazu
Joined Jul 9, 2009
Hello! I'm hoping someone could help me with this project I've been working on. I initially made and programmed a device using a PIC12F629 to simulate muzzle flash on a prop firearm. Now, I need to make a similar unit with sound playback. So far I've based my program on this project, though I am using a PIC16F1938 for the extra I/O pins that I will be needing later for a numeric display. My goal is to have it flash an LED, and play a very small (less than 70KB) WAV file every time the trigger is pressed. Also, I'm using Source Boost C++.
This is the original main.c designed for a PIC16F1825 in that project;
Rich (BB code):
#include "common.h"
  #include "SD.h"
  #define FLAG_TIMEOUT            0x80
  #define FLAG_PARAM_ERR            0x40
  #define FLAG_ADDR_ERR            0x20
  #define FLAG_ERZ_SEQ_ERR      0x10
  #define FLAG_CMD_CRC_ERR      0x08
  #define FLAG_ILLEGAL_CMD      0x04
  #define FLAG_ERZ_RST            0x02
  #define FLAG_IN_IDLE_MODE      0x01
  #pragma CLOCK_FREQ 32000000
  #pragma DATA _CONFIG1, _FOSC_INTOSC & _WDTE_SWDTEN & _PWRTE_ON   & _MCLRE_OFF & _CP_ON & _CPD_ON & _BOREN_OFF &   _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF
  #pragma DATA _CONFIG2, _WRT_OFF & _PLLEN_OFF & _STVREN_ON & _LVP_OFF
  void UARTInit(){
        // UART
        baudcon.4 = 0;      // SCKP       synchronous bit polarity
       baudcon.3 = 0;      // BRG16      enable 16 bit brg
        baudcon.1 = 0;      // WUE       wake up enable off
        baudcon.0 = 0;      // ABDEN      auto baud detect
        txsta.6 = 0;      // TX9       8 bit transmission
        txsta.5 = 1;      // TXEN       transmit enable
       txsta.4 = 0;      // SYNC      async mode
        txsta.3 = 0;      // SEDNB      break character
       txsta.2 = 0;      // BRGH      high baudrate
        txsta.0 = 0;      // TX9D       bit 9
        rcsta.7 = 1;      // SPEN serial port enable
        rcsta.6 = 0;      // RX9 8 bit operation
        rcsta.5 = 1;      // SREN enable receiver
        rcsta.4 = 1;      // CREN continuous receive enable
       spbrgh = 0;      // brg high byte
       spbrg = 51;      // brg low byte ()
        apfcon0.2=1;      // tx onto RA.0
  void UARTSend(unsigned char c){
       txreg = c;
        while(!txsta.1);
  void UARTPrint(char *s){
        while(*s) {
        UARTSend(*s);
        s++;
  void UARTPrint(char c){UARTSend(c);}
  void UARTPrintNumber(unsigned long n){
        unsigned long k=1000000000;
        while(k>0) {
              UARTSend('0'+n/k);
              n%=k;
              k/=10;
  void UARTPrintLn(char *s){
        UARTPrint(s);
        UARTPrint("\r\n");
  void UARTByte(unsigned char b){
        const char *hex="0123456789abcdef";
        UARTPrint("0x");
        UARTSend(hex[b>>4]);
        UARTSend(hex[b & 0xf]);
  void UARTLog(char *s, unsigned short iv){
        UARTPrint(s);
        UARTPrint(" ");
        UARTPrintNumber(iv);
        UARTPrintLn(" ");
 void fatal(UInt8 val){            //fatal error: flash led then go to sleep
        UInt8 i, j, k;
        for(j = 0; j < 5; j++){
             for(k = 0; k < val; k++)
                    delay_ms(100);
                    P_LED = 1;
                    delay_ms(100);
                    P_LED = 0;
             UARTLog("Error",val);
              delay_ms(250);
              delay_ms(250);
        while(1){
             asm sleep
So far, this is what I have modified it to, and included my muzzle flash coding. I know there's definitely something I'm not catching here, so please let me know any errors you might see. Also, I need to figure out how exactly to activate sound playback after the LED flash.
Rich (BB code):
#include "common.h"
 #include "SD.h"
 #include "PIC16F1938.h"
 #include "BoostC.h"
         _FOSC_INTOSC &        // INTOSC oscillator: I/O Functions
         _WDTE_OFF &            // WDT Disabled
         _PWRTE_ON &            // PWRT Enabled
         _MCLRE_OFF &        // MCLR/VPP pin function is Input
         _CP_OFF &            // Program memory code protection is disabled
         _CPD_OFF &            // Data memory code protection is disabled
         _BOREN_NSLEEP &        // Brown-out Reset Disabled During Sleep
         _CLKOUTEN_OFF &        // CLKOUT function is disabled. I/O or oscillator function on the CLKOUT pin
         _IESO_OFF &            // Internal/External Switchover mode is disabled
         _FCMEN_OFF            // Fail-Safe Clock Monitor is disabled
         _WRT_OFF &            // Write protection off
         _VCAPEN_RA0 &        // VCAP on RA0
         _PLLEN_OFF &        // 4x PLL disabled
         _STVREN_ON &        // Stack Overflow or Underflow will cause a Reset
         _BORV_25 &            // Brown-out Reset Voltage (VBOR) set to 2.5 V
         _LVP_OFF            // High-voltage on MCLR/VPP must be used for programming
 void MuzzleFlash(void)
     ansela = 0b00000000;     // ANSELA all Digital
     trisa = 0b00000111;        // Set Inputs
     porta = 0b00000000;        // All Outputs are 0
     for(;;)                    // Forever
     if(TRIG ==0)            // Debounce Check
         delay_ms(50);
             if(TRIG == 0)    // While TRIG switch held low
             MUZZ_LED = 0;    // MUZZ LED Off
             delay_ms(10);
             MUZZ_LED = 1;    // MUZZ LED On
             delay_ms(35);
             delay_ms(122);
 void UARTInit()
                             // UART
       txsta.6 = 0;            // TX9            bit transmission
       apfcon.1 = 1;            // SSSEL        SS on RA0
       txreg = c;
       while(!txsta.1);
       while(*s)
       UARTSend(*s);
       s++;
       UARTSend(c);
       while(k>0)
             UARTSend('0'+n/k);
             n%=k;
             k/=10;
       UARTPrint(s);
       UARTPrint("\r\n");
       UARTPrint("0x");
       UARTPrint(s);
       UARTPrint(" ");
       UARTPrintLn(" ");
 void fatal(UInt8 val)                    //fatal error: flash led then go to sleep
       UInt8 i, j, k;
                   delay_ms(100);
                   ERROR_LED = 1;
                   delay_ms(100);
                   ERROR_LED = 0;
             delay_ms(250);
             delay_ms(250);
       while(1)
             asm sleep
If you need to see my common.h or sd.h files, I can post them too. Thanks in advance!
