PIC16F1936 8-bit microcontroller
Discussion in 'Embedded Systems and Microcontrollers' started by bbcdancer, Jul 9, 2012.
  1. bbcdancer
    Jul 9, 2012
    I got a (PIC16F1936 8-bit) microcontroller and I was wonder what software and hardware I need to read what was written in this micro chip.
    Any suggestions be much appreciated.
  2. Markd77
    Sep 7, 2009
    You might not be able to read it if it was code protected (commonly done in commercial products).
    If it isn't protected then a PICKIT3 and MPlab will get you a HEX file from the chip. The HEX file isn't much use apart from to make copies as making it back into usable code is very time consuming and difficult.
  3. t06afre
    May 11, 2009
    A PICKIT 3 and MPLAB from microchip may do the job. But it is a BIG if. If the chip is code protected. You will not be able to get anything out of the chip. If it is taken from a commercial application. It is most likely that the chip is protected. However you do not know before you try it ;)
