hai all......
i want control input of optocoupler (LED) using pwm/DAC 10bit. Reason i want to used it because i want control the LED smoothly that is around <4mV for each variable......so i need PIC that have >10bit pwm/DAC. Because right now i use 8bit DAC n the result is bad....the optocoupler become so sensitive
