PIC12F675 Low
Discussion in 'The Projects Forum' started by RodneyB, Aug 27, 2013.
  1. RodneyB
    Thread Starter Active Member
    Apr 28, 2012
    649
    14
    I am building a circuit using a PIC12F675. The supply voltage is 4.9Volts. I need the voltage to go low as part of the circuit. I have used an LDR and a 33K resistor, The voltage drops to 3.4 Volts. Is this considered as a "LOW" in terms of an input for a PIC.
    My circuit does not seem to be seeing it as a low.
    any thanks
    Rodney
  2. tracecom
    Apr 16, 2010
    3,879
    1,396
    No, a PIC requires close to zero volts as a logic low. You probably will need a pull-down resistor; post a schematic.
  3. RodneyB
    Apr 28, 2012
    649
    14
    I have retested and the voltage does not go below 3.6 Volts. If I was to remove the 33k Resistor would the current flow through the LDR not damage it.
  4. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    You need to connect the LDR to an analog input and calculate the light level. It's not a digital device.
