PIC12F675 / Infrared Signal
Discussion in 'Programmer's Corner' started by Reed, Apr 3, 2006.
  1. Reed
    Apr 3, 2006
    complete
  2. Papabravo
    Feb 24, 2006
    10,338
    1,850
    There are at least a couple of critical pieces of information missing from your picture. Let us start with the basics.
    1. Do you have a copy of the PIC12F675 Datasheet?
    2. What frequency is the PIC12F675 running at?
    3. How often does Timer1 generate an interrupt?
    I think, but I am not 100% sure, that you can use the Timer1 Interrupt to detect the presence of a burst. You can measure the time between bursts to detect the quite period. Then you can measure the length of a burst in Timer1 interrupts and determine the difference between a zero and a one. There may be other details and it might be easier to do if more resources are available.
    Could you post the circuit so I can see what the six non power pins are doing?
    Hope this helps
  3. Reed
    Apr 3, 2006
    correction
  4. Reed
    Apr 3, 2006
    complete
