PIC12F675 external clock in SLEEP simulation
Discussion in 'Embedded Systems and Microcontrollers' started by Markd77, Dec 4, 2009.
  1. Markd77
    Thread Starter Senior Member
    Sep 7, 2009
    2,803
    594
    I'm tring to simulate a 12F675 in MPLab sim to wake from sleep on timer1 overflow with a 32.678KHz crystal. The datasheet says timer1 should still count in SLEEP but it just stays at the value I set it to. I can see GPIO, 5 changing so the stimulus I set up to simulate the external crystal is doing something.
    I think I have the interrupt registers, T1CON, etc set up right but I might have done something wrong.
    The attached screen capture should explain things.
    If I comment out sleep then timer1 increments and the interrupt gets called.
    What should I do?
    Edit: Additional info:
    Problem now solved (I didn't realise I had to set T1CON, T1SYNC)
