PIC12F629 2.5 minutes delay at start up the first time
Discussion in 'Embedded Systems and Microcontrollers' started by Rogerspierre, Feb 20, 2011.
  1. Rogerspierre
    Feb 20, 2011
    I'm working with a pic 12f629, when it's first powered on (i.e. in the morning) it takes about 2.5 minutes to work fine. If I shut off it in the next minutes and power it on again it works fine, It seems that needs some time in the first power on to warm up and then it works as planed, after that I shut it off (removing the power supply) and turn it on again and works fine! have you have some problem like that?
    Thank for your help before hand!!
  2. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Post your schematic & source code.
  3. thatoneguy
    Feb 19, 2009
    6,357
    718
    That isn't normal behavior. Have you checked your power supply for ripple and output current/voltage?
    Semiconductors do not need to "warm up" before functioning. Other components, such as capacitors and some sensors do sometimes need to "warm up", but they are typically the exception rather than the rule in a functioning well designed circuit.
  4. spinnaker
    Oct 29, 2009
    5,065
    1,163
    Didn't the 12f629 use vacuum tubes? :)
  5. thatoneguy
    Feb 19, 2009
    6,357
    718
    It's ancestor, ENIAC, yeah. :D
    It's quite amazing that an 8 pin IC that uses milliwatts has computing abilities that fully eclipse a warehouse sized computer that needed kilowatts to run. With no warm up time either!
