hello, im working on 3 button rf remote control system, my final circuit design can be found at the bottom of page 2 on my circuit design thread. this is my first time programming a pic, actually any ic for that matter.
the website said that when a button is pressed on the transmitter the corresponding relay (for programmings sake) will turn on, and if another is pressed it will turn on as well, then if the same corresponding button is pressed it will turn off, everything works separately.
what i want it to do is, on power up, relay 1 by default is on and 2 and 3 are off. then for example if button 3 is pressed, relay 1 will turn off and relay 3 will turn on. i want only 1 relay to stay on at a time
the code is written in c, (which i haven't learned yet) and i can't seem to figure out how to change what i want done, can someone please help me on that?
also on page 16 of my thread, pencil said that because of the type of mosfet used, the operation of the uc must be changed, how exactly would i do that? just reverse the pin's output?
thank you in advanced!
seesoe
seesoe
Rich (BB code):
// Receiver for RF remote control project
// (c) www.CoolCircuit.com
#include<pic.h>
#include"delay.h"
__CONFIG(XT&MCLRDIS&WDTDIS);
#define Header 0x20
#define RX GP3
#define out1 GP0
#define out2 GP1
#define out3 GP2
unsigned char RXREG[3];
unsigned char toggle=0x00;
unsigned char old_toggle=0x00;
#define Channel RXREG[1]
bit get_data(unsigned char *buff);
bit rx_bit;
void main()
DelayBigUs(580);
GPIO=0x00;
TRIS=0B00001000;
OPTION=0x03;
while(1)
while(get_data(RXREG));
if (RXREG[2]==(RXREG[0] ^ RXREG[1]))
if (RXREG[0]==Header)
toggle = RXREG[1] & 0x80;
if (toggle!=old_toggle)
old_toggle=toggle;
RXREG[1]=RXREG[1] & 0x03;
if (RXREG[1]==0x01) out1=!out1;
if (RXREG[1]==0x02) out2=!out2;
if (RXREG[1]==0x03) out3=!out3;
//DelayMs(50);
unsigned char i,j,T0,count;
i=35;
count=0;
OPTION=0x00; // pre scaler = 2 for counting long time
while(--i) // wait preamble
NOP();
NOP();
NOP();
while(RX);
TMR0=0;
NOP();
NOP();
NOP();
while(!RX);
T0=TMR0;
if (T0==0xFF) return 1; // error
if ((T0>=198) && (T0<=218)) // 396-432 uS it OK.
count++;
if ((count>=1)|| (i==0)) break;
if (i==0) return 1; // error
OPTION=0x03; // prescaler = 16
//OPTION=0x04; // prescaler = 32
T0=0;
while (!((T0>=94) && (T0<=114))) // 1504 - 1824 uS it OK. syn bit for 4Te or 1664 uS
//while (!((T0>=158) && (T0<=180))) // 5056 - 5760 uS it OK. syn bit for 4Te or 5416=5mS+ (4*416uS) uS
NOP();
NOP();
NOP();
while(RX); // wait syn
TMR0=0;
NOP();
NOP();
NOP();
NOP();
while(!RX);
T0=TMR0;
while(RX); //wait start bit go low
DelayBigUs(580); // delay 624 uS before sampling (1.5Te)
for (j=0;j<3;j++)
i=8;
buff[j]=0;
while(i--)
buff[j]=buff[j]<<1;
rx_bit=RX; // sampling
buff[j]=buff[j] | rx_bit;
if (rx_bit==0)
while(!RX);
else
while(RX);
DelayBigUs(580); // delay 7500 uS before sampling
if (rx_bit==0)
if (!RX) return 1; // error (no stop bit found)
else
return 0;
