1. sushilreddi
    Jan 16, 2014
    dear friends
    i am new to this field
    i need a pic program in flow code i will explain the program
    there a 4 inputs 1st up
    2nd down
    3rd reset
    4th sensor
    out puts 2 pwm controlled motor op 1 is constant 1 is variable
    1 relay output
    2nd 1 buzzer output
    there is a lcd to display the counts
    flow of the program
    when we switch on the circuit the relay must be on and the both the motor must start, 1 is constant speed and 1 is variable speed
    speed must show in the lcd (16X2) 0-120rpm
    if i clicked on up button then speed must increment +10 (ex if it is running in 60 then it will jump to 70 using pwm )
    if i clicked on down button then it must decrements -10
    if the sensor input remains for 1 sec then motors and relay must be off and buzzer must switch on.
    that timer is user friendly so it must be variable and we need to change using same push button in lcd.
    if i clicked on reset button then system start again same thing will repeat
  2. pwdixon
    Member
    Oct 11, 2012
    488
    56
    You can do all of this but I doubt anyone will just do the coding for you, you should do it yourself or be prepared to pay someone to do it for you.
  3. R!f@@
    Apr 2, 2009
    8,791
    771
    We do not code but can help if ur code is not working.
  4. tshuck
    Oct 18, 2012
    3,531
    675
    I would suggest either learning how to use the PIC, then apply that knowledge to the solution you are attempting, or picking a controller with a smaller learning curve (e.g. an Arduino, or a PICAXE)...
