PIC XC8 compiler data space question
Discussion in 'Embedded Systems and Microcontrollers' started by bug13, Dec 7, 2015.
  1. bug13
    Feb 13, 2012
    1,213
    38
    Hi guys
    I think I am about to run out of data space in my pic, so how reliable of the data space info generated by the mplab X when a project is compiled?
    eg, the data space info below:
    Thanks a lot!
  2. spinnaker
    Oct 29, 2009
    5,065
    1,164
    You should be able to compute it yourself by adding up all of the space in your variables. Data sizes are listed in the compiler manual. Here is the one for integers
    But I would say the memory summary is accurate.
    This really should be in the embedded forum.
    bug13 likes this.
  3. JohnInTX
    Jun 26, 2012
    2,393
    1,051
    Moved to Embedded Systems and Microcontrollers.
    The summary is usually pretty close and includes the memory that the compiler assigns for run time variables (software stack etc).
    If you start running low, review your code to see if you can put constants in ROM, declare temp variables inside functions etc. so that the compiler knows it can reuse them.
    XC8 is pretty good at packing in the bytes. Maybe you need a bigger PIC. Which one are you using?
    bug13 likes this.
  4. bug13
    Feb 13, 2012
    1,213
    38
    Good to know that the compiler is pretty good.
    I am using pic18f46j50, 64K rom, 3.7K ram. unfortunately, my codes are almost done, and I don't really want to change if I don't have to.
  5. spinnaker
    Oct 29, 2009
    5,065
    1,164
    I would take a look at your code. See if you can make use of the stack rather than declaring everything global there may be some variables you can declare inside functions.
    bug13 likes this.
  6. bug13
    Feb 13, 2012
    1,213
    38
    What do you mean by making use of the stack? Would you explain a bit more?
  7. spinnaker
    Oct 29, 2009
    5,065
    1,164
    Say for example you have a variable.
    Code (Text):
    1.
    2.
    3. int x;
    4.
    5. void foo()
    6. {
    7.
    8.   x =1
    9.
    10. }
    11.
    In this case x will remain in memory the life of your program. It is fine if x is going to be used my a lot of functions.
    But say it is only used by foo. Then you could do this.
    Code (Text):
    1.
    2.
    3. void foo()
    4. {
    5.    int x = 1;
    6.
    7.
    8. }
    9.
    In this case the space x takes up will be freed when foo exits. It uses the stack.
    bug13 likes this.
  8. bug13
    Feb 13, 2012
    1,213
    38
    Got it, thanks for explaining!!
  9. spinnaker
    Oct 29, 2009
    5,065
    1,164
    Look at section titled How Can I Reduce RAM Usage? in the XC8 manual for other tips. In mine it is section 3.6.3.
    bug13 and JohnInTX like this.
  10. spinnaker
    Oct 29, 2009
    5,065
    1,164
    Another little trick you can use to save a bit of memory.
    Code (Text):
    1.
    2.
    3. Say you have 8 flags
    4.
    5.   unsigned char flag1;
    6.   unsigned char flag2;
    7.   unsigned char flag3;
    8.   unsigned char flag4;
    9.   unsigned char flag5;
    10.   unsigned char flag6;
    11.   unsigned char flag7;
    12.   unsigned char flag8;
    13.
    14. This takes 8 bytes of memory when it really just needs to take 8.
    15.
    16. You can use the bit operator.
    17.
    18. struct flagstype
    19. {
    20.   unsigned char flag1 : 1;
    21.   unsigned char flag2 : 1;
    22.   unsigned char flag3 : 1;
    23.   unsigned char flag4 : 1;
    24.   unsigned char flag5 : 1;
    25.   unsigned char flag6 : 1;
    26.   unsigned char flag7 : 1;
    27.   unsigned char flag8 : 1;
    28.
    29. };
    30.
    31. This only takes on byte.
    32.
    33.
    34. If you have a 2 counters that only need to go to 15  you can do this
    35.
    36. struct countertype
    37. {
    38.   unsigned char counter1 : 4;
    39.   unsigned char counter2 : 4;
    40.
    41. };
    42.
    43.
    44.
    45.
    46.
    bug13 likes this.
  11. MMcLaren
    Feb 14, 2010
    759
    116
    Wouldn't a four bit counter top out at 15?
  12. spinnaker
    Oct 29, 2009
    5,065
    1,164
    Duh! Not thinking yeah 15. Too long a day today. o_O
