Hi E,If you wanted to stay with the 16F series, the 16F877A is a 40 pin PIC.
I would avoid connecting two PIC's together, unless one is doing a lot of Maths.
The 18F4520 40 pin, does have some program instructions that would be helpful for Tables.
Well it works better then nothing! I existed this way for years until the free tools came from Microchip and my little PICkit suddenly became an in circuit debugger. That way I can see any variable at any time, no less trace down the code itself while it executed.Using 16 PICs, to work on the program. I will be working with lists of data, where the program compares data with data. I will need some kind of way of seeing the results. Is the LCD module in Oshonsoft best for this?
Hi Ernie,Well it works better then nothing! I existed this way for years until the free tools came from Microchip and my little PICkit suddenly became an in circuit debugger. That way I can see any variable at any time, no less trace down the code itself while it executed.
Yeah, just an LCD works too. I keep a pile (literally, there are 3 extras in my box) of cheap EBay 4 line 20 character displays here just to drop into projects. I also have a PCB to add 5 pushbuttons to them that lets one control the program, as the port driving the LCD can support up to 6 buttons on the same lines.
So both ways work, but I do prefer the debugger for debugging; one does not have to write special and perfect code just to inspect things.
I don't think I will need tables.If you wanted to stay with the 16F series, the 16F877A is a 40 pin PIC.
I bow to your knowledge. I only have a simple unsmart phone, and laptops, but I have the Microchip selector. It is quite a task selecting the correct one, especially with my limited knowledge. I hope for experienced suggestions.You said earlier, that the program compares lists of data with data ....
So you certainly need tables.
Btw. if you have Android tablet or phone, there is free application Pic micro database, which is handy for selecting the right pic for your needs.
Thread starter | Similar threads | Forum | Replies | Date |
INTERRUPTS in Oshonsoft basic | Microcontrollers | 12 | ||
Ublox GPS checksum in Oshonsoft BASIC | Microcontrollers | 29 | ||
Wrongly READ BITs from peripheral, error? Oshonsoft BASIC | Microcontrollers | 98 | ||
Adding BYTEs into a STRING Oshonsoft BASIC | Microcontrollers | 39 | ||
18F4620 Analog in puzzle in Oshonsoft Basic | Microcontrollers | 2 |
by Duane Benson
by Robert Keim
by Aaron Carman
by Jake Hertz
