1. R!f@@
    Thread Starter AAC Fanatic!
    Apr 2, 2009
    8,792
    771
    I am planning to use separate Vref with ADC.
    My question, is should I bypass the Vref+ or not. The Vref will be taken separate from another circuit with jumper wires less than a feet together with ADC which I want to check.
  2. ErnieM
    Apr 24, 2011
    7,442
    1,628
    Yes, absolutely add bypass, both at the ref source and at the PIC.
    A bit of series impedance isn't a bad idea either, say 100 ohms to give the cap something to break against.
    And your oscilloscope will be your friend here for design validation.
  3. R!f@@
    Apr 2, 2009
    8,792
    771
    OK...a 100nf as the Vref+ to bypass it.
    I am not sure why a 100R series with the Vref+
    Can you explain why.
  4. ErnieM
    Apr 24, 2011
    7,442
    1,628
    It gives the cap something to work against, so the noise stays on the ref side and not on the pic side.
  5. R!f@@
    Apr 2, 2009
    8,792
    771
    100R at the Vref+ input side and a 100nf at the Vref+ pin of the PIC
