Pic USART - Why do I need to enable receive??
Discussion in 'Embedded Systems and Microcontrollers' started by spinnaker, Nov 18, 2012.
  1. spinnaker
    Thread Starter AAC Fanatic!
    Oct 29, 2009
    5,062
    1,160
    Why do I need to enable receive?? I'm working with the pic usart on a Pic18f. I see from the data sheet that receive needs to be enabled to get the uart to work.
    I thought I read that wrong or just didn't understand. Well I just tried it. If I disable RX than TX is disabled too!
    That makes no sense to me at all. Why do I need RX? What if I have an application that just transmits? Why should I have to tie up a pin just to get it to work
  2. nsaspook
    Aug 27, 2009
    3,006
    2,349
    It's just how the pin mux was designed. I think the RX/TX pins can still be using for digital input just not digital output when SPEN = 1.
  3. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Yep it's a nasty kludge by Microchip and has annoyed me a lot over the years especially when working with a PIC that has limited pins!
    NSAspook is right the RX input pin will still work as a general digital input, as when reading a port the PIC always reads the voltage on the pin itself.
    So you can enable the USART and just read the RX pin as a normal digital input, or another option is to code up a manual USART function (which is quite easy) and manually send serial data out a pin, any pin you like. Manual USART might tie up the PIC while it is actually transmitting, but that might still be ok.
