PIC USART Problems
Discussion in 'Embedded Systems and Microcontrollers' started by crazyengineer, Sep 27, 2012.
  1. crazyengineer
    Dec 29, 2010
    156
    Hello everyone. I'm trying to write hello world to a serial program. However, when I ran the following code
    Code ( (Unknown Language)):
    1.
    2. #include <p18F2420.h>
    3. #include <delays.h>
    4. #include <usart.h>
    5. #pragma config OSC = INTIO67
    6. #pragma config WDT = OFF
    7. #pragma config PBADEN = OFF
    8. #pragma config LVP = OFF
    9.
    10.
    11.
    12.
    13. void main()
    14. {
    15.     TRISC=0x00;
    16.     OpenUSART(USART_TX_INT_OFF & USART_RX_INT_OFF & USART_ASYNCH_MODE &USART_EIGHT_BIT & USART_CONT_RX & USART_BRGH_HIGH, 51);
    17.     while(1)
    18.     {
    19.         while(BusyUSART());
    20.         putrsUSART("Hello");
    21.     }
    22.
    23. }
    24.
    Keep in mid I'm using the internal osc of the PIC18F2420.
    I see nothing displayed in the serial program, but the cursor moves
  2. MrChips
    Oct 2, 2009
    12,624
    3,451
    Have you made certain that the two baud rates are the same?
    Try using an external xtal instead of the internal oscillator.
    crazyengineer likes this.
  3. crazyengineer
    Dec 29, 2010
    156
    Works perfectly now. Just the confusion of the internal clock was messing me up. I switched to an external 20MHZ clock the whole thing works marvelously!
  4. t06afre
    May 11, 2009
    5,939
    1,222
    If you use Hi-Tech C you must define the clock frequency in your code.
  5. lawncegary
    Sep 27, 2012
    6
    I switched to an external 20MHZ clock the whole thing works marvelously![​IMG]
