PIC uC using Vcap
Discussion in 'Embedded Systems and Microcontrollers' started by R!f@@, Dec 7, 2015.
  1. R!f@@
    Thread Starter AAC Fanatic!
    Apr 2, 2009
    8,787
    771
    I have a bit of confusion.:(
    Q1.) Does PIC16F876A & PIC16F886 uses Vcap ?
    Q2.) If I need In circuit debugging should I leave the PGC and PGD only for that purpose ? I can if it needs to.
    Q3.) Do I need PGM pin fro debugging ? I am planning to use it as a I/O. Do I need that pin free as PGM so I will not get confused while coding and debugging. I know I will if I plan to use that pins as I/O later.
    Please do not over complicate the answer. I am confused as of now.:oops:
    Too much confusing info and I will have to move to a friendly 16F88. ( too little I/O's ).
    I like to get to know this PIC ( 876 and 886, as they are pin compatible ).
    PS. This is for access controller.:p
  2. hexreader
    Apr 16, 2011
    250
    82
    A1.) No
    A2.) A good idea if you can
    A3.) No, Disable LVP in configuration bits and the PGM pin becomes just another I/O pin
    R!f@@ likes this.
  3. R!f@@
    Apr 2, 2009
    8,787
    771
    That's simple enough to undrestand:D
