PIC Turning on when I touch ground.
Discussion in 'Embedded Systems and Microcontrollers' started by TrevorP, Jan 31, 2009.
  1. TrevorP
    Thread Starter Active Member
    Dec 8, 2006
    Hey all,
    I'm just messing around with microcontroller programming so a friend has lent me his protoboard and pic16f88. So I've got the chip coded to simply flash an led at one rate if a pin reads high. And faster if it doesn't.
    What's weird is that the chip won't turn on until I hold my finger to the ground line somewhere. Once I do it seems to work perfectly. I've got the following fuses set on the chip:
    WDT - Disabled
    MCLRE - Disabled
    Code Protect Rom - Disabled
    Oscillator - INTRC_CLKOUT
    Debug - Disabled
    LVP - Enabled
    Switch Over Mode - Enabled
    PWRTE - Disabled
    BODEN - Disabled
    Code Protect EEP - Disabled
    CCPMX - CCP1 RB0
    FLASH Write Protect - Disabled
    Fail Safe - Enabled
    And attached is a schematic of the chip right now. (some of the pinouts aren't the same on that block diagram because it's actually for a chip other than the 88. But I have it wired correctly.) It also should be running on the internal oscillator.
  2. TrevorP
    Dec 8, 2006
    Doesn't the pic have internal pull-up resistors?
