I'm working on a circuit which is to use a PIC output pin to toggle a relay. The 5VDC relay I am using has ~70ohm coil resistance to be driven from a PIC16F886. It seems that the uC cannot supply enough current to toggle the relay.
I'm assuming my problem could be accomplished by placing a FET or BJT in between the two, only I'm not exactly sure how to do that. Can anyone recommend a part number and circuitry to do this?
Thanks.
Thanks.
