PIC Timer for Rainwater Pumps
Discussion in 'Embedded Systems and Microcontrollers' started by bobbutton, Feb 13, 2013.
  1. bobbutton
    May 24, 2011
    Rainwater Harvesting Pump Delay Unit
    I am fairly new to programming PICs, but what to use one for the following project.
    If there is anybody that can assist me in writing the program to achieve the following I would very much appreciate it.
    I need to build a delay unit for the pumps in my rainwater harvesting system
    This is due to the slow reaction of an electrically operated valve and the rippling of the water in the tanks turning the float switches on and off
    There are two 12v pumps in the system
    The first is a submersible pump fitted in the underground rainwater storage tank. Its job is to prime the main pump which is above ground. I will call this pump :- sump_pump
    The second is the main pump which lifts the water to the tanks in the loft. I will call this pump :- main_pump
    The Micro Controller I want to use is the PIC 12F629 and
    programmed in C
    Inputs and Outputs are as follows
    Single Input From existing control system
    GPIO 2 Pin 5 Quiescent state High
    Output Sump_pump Turn on sump pump via a relay
    GPIO 4 Pin 3 Quiescent state Low
    Output Main_pump Turn on main pump via a relay
    GPIO 5 Pin 2 Quiescent state Low
    Output LED 1
    GPIO 0 Pin 7 Quiescent state Flashing
    This LED has two jobs
    First Job :- Heartbeat flashing all the time, short on about 2 sec off, shows pic is OK
    Second Job :- Show first timer is working, flash at about 1 Hz
    Output Pump_Run_Timer Turn on a timer to record pumps run time
    GPIO 1 Pin 6 Quiescent state High
    Reset Reset PIC
    MCLR Pin 4 Quiescent state High
    Program Sequence
    Change of State
    1 Quiescent State Input GPIO 2 High
    Sump Pump Off Output GPIO 4 Low
    Main Pump Off Output GPIO 5 Low
    LED Short Flash Output LED GPIO 0 Short Flash
    Pump Run Time Off Output GPIO 1 High
    2 Start Input Goes Low Input GPIO 2 Goes Low
    Output GPIO 4 Low
    Output GPIO 5 Low
    Flash LED 1 Hz Output LED GPIO 0 Flash 1 Hz
    Output GPIO 1 High
    3 If at any time Input GPIO 2 Goes High goto 1
    4 Wait between 15 and 45 sec "to be set under test"
    5 Input GPIO 2 Low
    Turn Sump Pump On Output GPIO 4 High
    Output GPIO 5 Low
    Pump Run Time On Output GPIO 1 Low
    6 Wait between 2 and 10 sec "to be set under test"
    7 Input GPIO 2 Low
    Output GPIO 4 High
    Turn Main Pump On Output GPIO 5 High
    Output GPIO 1 Low
    8 Wait between 5 and 45 sec "to be set under test"
    9 Input GPIO 2 Low
    Turn Sump Pump Off Output GPIO 4 Low
    Output GPIO 5 High
    Output GPIO 1 Low
    10 From now on
    All the time Input GPIO 2 Stays Low
    Output GPIO 4 Low
    Output GPIO 5 High
    Output GPIO 1 Low
    11 At this or any other time if Input GPIO 2 Goes High goto 1
  2. Lourens
    Jul 16, 2012
    14
    Hi Bob
    I have a visual programming system which is ideal for this kind of application. It is based on function blocks, contains a simulator and can monitor/debug the pic application in real time. It is distributed free BUT it is only for PIC18F.
