I'm trying to use the code provided by Microchip to debounce the switch, but I couldn't really understand the code itself:
// This lesson shows one method to software debounce a switch input.
// The switch is sampled once every millisecond and must be low for
// 5 samples in a row to register a "press". Each press rotates
// the LEDs on PORTD.
#include "p18f45k20.h"
#include "delays.h"
#include "04 Switch Input.h" // header file
/** V A R I A B L E S *************************************************/
#pragma udata // declare statically allocated uinitialized variables
unsigned char LED_Display; // 8-bit variable
/** D E C L A R A T I O N S *******************************************/
#pragma code // declare executable instructions
void main (void)
unsigned char Switch_Count = 0;
LED_Display = 1; // initialize
TRISD = 0b00000000; // PORTD bits 7:0 are all outputs (0)
INTCON2bits.RBPU = 0; // enable PORTB internal pullups
WPUBbits.WPUB0 = 1; // enable pull up on RB0
ANSELH = 0x00; // AN8-12 are digital inputs (AN12 on RB0)
TRISBbits.TRISB0 = 1; // PORTB bit 0 (connected to switch) is input (1)
while (1)
LATD = LED_Display; // output LED_Display value to PORTD LEDs
LED_Display <<= 1; // rotate display by 1
if (LED_Display == 0)
LED_Display = 1; // rotated bit out, so set bit 0
while (Switch_Pin != 1);// wait for switch to be released
Switch_Count = 5;
do
{ // monitor switch input for 5 lows in a row to debounce
if (Switch_Pin == 0)
{ // pressed state detected
Switch_Count++;
else
Switch_Count = 0;
Delay10TCYx(25); // delay 250 cycles or 1ms.
} while (Switch_Count < DetectsInARow);
1. I don't understand what do the #pragma udata and #pragma code work for.
2. For the first while(Switch_Pin != 1), could it be replaced by while(Switch_Pin == 0)?
3. I wonder why the Switch_Count=5 is declared as this way, because if it is to work as the comment stated above(sample 5 consecutive low), I thought it should be Switch_Count=0, because from my understanding of the code, it will immediately loop out of the while(Switch_Count < DetectsInARow) once it detected a pressed state by incrementing Switch_Count to 6, and if the user is fast enough to press the switch before the code loads tilll Switch_Count=5, hehehe...
#include "delays.h"
void main (void)
while (1)
Switch_Count = 5;
do
Switch_Count++;
else
Switch_Count = 0;
