pic simulation
Discussion in 'Embedded Systems and Microcontrollers' started by mosajawdet, Mar 5, 2013.
  1. mosajawdet
    Mar 5, 2013
    6
    Hi
    I'm made a program in micro c for pic16f877a but when i make a simulation using Proteus the program work the first step ok but the second no can help me ? my program :
    void main() {
    char i;
    trisd=0x00;
    portd=0;
    while(1){
    Portd.f0=1;
    Delay_ms(30000);
    Delay_ms(30000);
    Delay_ms(30000);
    Delay_ms(30000);
    portd.f0=0;
    for( i=1; i==120 ;i++);
    Delay_ms(30000);
    Delay_ms(30000);
    the delay for tow hours doesn't work
  2. tshuck
    Oct 18, 2012
    3,531
    675
    Code ( (Unknown Language)):
    1. [COLOR="lime"]Your condition is false and will exit the loop[/COLOR]
    2. for( i=1;[COLOR="Lime"] i==120[/COLOR] ;i++)[COLOR="Red"];<- this semicolon means the for loop has no body[/COLOR]
    3. {
    4. Delay_ms(30000);
    5. Delay_ms(30000);
    6. }
    ErnieM likes this.
  3. mosajawdet
    Mar 5, 2013
    6
    Dear :
    I remove the semicolon but after one minute the port goes on it must be off for tow hours
  4. tshuck
    Oct 18, 2012
    3,531
    675
    ...did you fix what I hi-lighted in green?
  5. mosajawdet
    Mar 5, 2013
    6
    yes i do (i==120 )
  6. tshuck
    Oct 18, 2012
    3,531
    675
    So, when the for-loop initialization sets i = 0, then tests whether i == 120, and evaluates to false( 0 != 120), this is desired operation?:confused:
  7. mosajawdet
    Mar 5, 2013
    6
    i make the for like this
    for( i=0; i==120 ;i++)
    but doesn't work :confused:
  8. tshuck
    Oct 18, 2012
    3,531
    675
    Yes, see my reasoning from the post you quoted.. You are setting i to 0, then entering the loop if i is 120, since it isn't, the loop isn't executed.
    FOR loop
  9. mosajawdet
    Mar 5, 2013
    6
  10. tshuck
    Oct 18, 2012
    3,531
    675
    Your conditional statement is wrong. Again, go read the link I supplied in the previous post.
  11. mosajawdet
    Mar 5, 2013
    6
    you mean using if statement
  12. thatoneguy
    Feb 19, 2009
    6,357
    718
    With your current usage, the test condition of i==120 will only run the loop if i==120, since the assignment starts by setting i=0, the loop will not run. If your initial assignment sets i=120, the loop would run one time.
    If you change i==120 to i<120, then i<=120 will be true, and it will run the loop until i > 120.
  13. tshuck
    Oct 18, 2012
    3,531
    675
    I was hoping the OP could be bothered to read through the link so he/she would understand why it should be i <= 120, but there it is...
    @OP: Please try to help yourself and read the link provided....
  14. ErnieM
    Apr 24, 2011
    7,436
    1,625
    I believe the OP is a non-english speaker. That must be tough trying to figure out what is being said, then figure out what that means.
    thatoneguy likes this.
  15. tshuck
    Oct 18, 2012
    3,531
    675
    ...ah yes, that would make sense....
    ...you can lead a horse to water, but you can't make it read Chinese...
